Question about Kodak ESP 5 Printer
PLUGGED PRINTER INTO COMPUTER WITH USB... COMPUTER CANNOT COMMUNICATE WITH PRINTER...IT IS AN ESP 5 ALL IN ONE
  • 385 Answers
Remove the USB and un-plug the printer. wait 5 mins.
Reboot, wait till your fully booted up, and at the desktop.
plug the printer in, switch it on,
Jack it to the Pc,( last job )
Press the F5 function key a few times to flush the Pc,
The computer should recognise the device
Making the " bing " noise.
If not, test the USB port with another device.
Should be good now
Regards
Richard.
Posted on Apr 24, 2009
When printers USB cable is plugged in it is not recognised. Driver installs ok butcomputer does not communivate with printer.
Unless your printer main board has failed, the only reason that a USB connection would not communicate is if your printer is turned off or if the USB printer cable or connection is faulty. Try connecting other equipment with the cable and see if that gets recognised by your computer also try connecting to a different USB socket on your computer.
Hope this helps.
Jan 22, 2011 | Xerox Phaser 3150/B Laser Printer
New computer lost printer disc can't download to new computer where can i get a startup disc so i can still use my printer
Your User Guide and drivers are available here:
http://support.en.kodak.com/app/answers/detail/a_id/19191/~/kodak-esp-5-all-in-one-printer%E2%A0%E2%80%94%E2%A0user-guide
Suggest you access the internet and download to a USB jumpdrive from which you can install on your computer.
If you must have the install disc, contact Kodak via their website to see if they are able to provide.
Trust this is helpful. Please vote.
Dec 12, 2010 | Kodak ESP 5 Printer
My kodak esp printer does have paper in the printer, put my computor tells me I am out. Also when I try to print something the printer, doesn't respond. But when I go direct to the printer and get it to...
The computer and printer are not connected - check the Device Manager to see if the printer is listed as well as its' driver. You must install the driver in order for the computer to communicate with the printer.
Nov 01, 2010 | Kodak ESP 5 Printer
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
Jul 10, 2010 | Kodak ESP 5 Printer
Need help installing kodak esp-5 printer . I just bought an hp pavilion pc series 2159m. I cannot get printer to work.
Get the software/drivers from Epson http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=12998/12999&product=EKN035324
If you have installed the drivers before connecting the printer to the computer, try a new USB cable and plugging into a different port. If you use a print server or a hub, go for a direct connection. Make sure the printer is online and has good ink.
I hope this helps.
(btw: pavilion 2159m is just your monitor so what OS does your computer have?)
Apr 11, 2010 | Kodak ESP 5 Printer
Printer cannot communicate with computer. When the printer is plugged in with a USB cable it recognizes and installs, however when I try to print anything, it comes up with a window saying that the...
You can try this T/S from the manufacturer's support site!
http://support.lexmark.com/index?page=content&id=SO4473&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1267057823425
Feb 25, 2010 | Lexmark Z1420 Printer
I recently purchased a Kodak esp5 all in one. I
Make sure that the printer is connected to your computer and you have the home center software installed on your system. Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Sep 05, 2009 | Kodak ESP 5 Printer
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
Kodak ESP 5 Printer Logo
143 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
