Question about SAMTRON 55V 15" CRT Monitor
Monitor Menu Settings
My Monitor Menus is not working correctly. i can't set my monitor colors and can not set h-Size or V-Size of monitor screen. then monitor screen is not showing full screen picture.
    President:
  • 2,022 Answers
If you have hair dryer just give little bit of heat on the panel button and make sure your monitor is complete off. see if it help otherwise give for repairing. bye
Posted on Sep 25, 2007
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
RE: ASUS eee When booting the eee shows the Windows screen as normal but when Windos starts, the screen is sideways. Can you tell me why?
try to adjust the setting on your monitor, the video card must be set on the resolution of your monitor...
let me know...
Jul 05, 2008 | Computers & Internet
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
I use an lcd screen. I've just reinstalled my Windows xp. But the desktop screen doesn't display fully. Left side & right side has some space. I set my screen resolution at 1024 by 768 pixels &...
The monitor should have some buttons on it to enter the menu system for the monitor. as part of the settings there should be options for vertical/horizontal size and position. You will need to adjust these to bring your borders to the correct position.
May 21, 2010 | Computers & Internet
Need to get screen size to show all . cant see
Things to check: Are your display settings set to "native resolution" of your screen. The native resolution is the actual dimensions (in pixels) of your flat-panel screen.
Looks like the Dell E153FP 15" has a native resolution of 1024x768. In windows, go to your control panel, in display settings, and ensure the resolution is set to 1024x768.
If that does not work, you can try the "auto adjust" feature on the monitor. On many Dell monitors, you can get this by pressing and holding the + button (on the monitor). You'll see the words "auto-adjust" appear on the screen if this works. If that doesn't work, you may be able to find auto adjust by navigating the menues in your monitor's menu, which you can get to by pressing the "menu" button on your monitor (sometimes this looks like a little rectangle icon). If it's an alignment problem, this should fix it right away.
If neither of the above work, it's probably your video card. Make sure your video card drivers are the correct ones for your card and OS, and up to date. You can also mess with display options under Control Panel > Display, under the "settings" tab, and at the bottom click the "Advanced" button, and it will bring up the advanced settings for your videocard.
Apr 23, 2010 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
Monitor
Try pressing the menu button and holding for 15 seconds or more. I have heard this will unlock most locked menus.
Oct 02, 2007 | Philips 107E56 17" CRT Monitor
there is in the menu that calls for " RECALL ", press this to go to original setting, and change setting again to your choice, individually.
Sep 25, 2007 | ViewSonic G810 21" SuperClear CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
123 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
