Question about Watches
Elgin fg2020 the seconds dial works but the minute hand does not move.
  • 2976 Answers
SOURCE: Casio Lineage Waveceptor 4717 minute hand off by 20 seconds
You would have to remove the movement from the case, remove the hand and reinstall it, to where you want it.
Posted on Aug 06, 2009
Sundar2579
  • 26 Answers
SOURCE: minute hand and second hand
There is a tool available in the market to remove second hands.
If you have a watch screwdriver you can easily remove both the hands. Just keep the screwdriver in between minute hand and second hand and gently twist the screwdriver. But be careful, it may damage the dial.
Posted on Sep 07, 2009
  • 183 Answers
SOURCE: Tissot PRS 200 hour and mnute hands not advancing.
I may not be clear on the problem here but it sounds like you may only need a battery change. If the battery is not the problem you can ask that your watch by placed on a cyclonic to force the gear train and free up small particle(s) that might be holding it up. This will be the fastest and least expensive. There is the chance this may require a more complicated repair but this till give you a starting point.
I suggest going to a watchmaker/technician who is familiar with working on this brand and be able to seal the watch back to its water resistant rating. This will take having a pressure chamber on site.
Posted on Sep 25, 2009
  • 5 Answers
SOURCE: Resetting stopwatch dials - Armani AR5331
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Posted on Jan 04, 2010
disap1
  • 98 Answers
SOURCE: The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Posted on Jan 09, 2010
My wenger sport elegance chronograph watch stopped working after 2 months. I bought it brand new. After readjusting the time, it worked for about 8 more hours, and then died again. The small dial on the...
You should change the battery, it is the cheapest thing to try. The batteries can be very old before they are installed and could have been in the watch a long time before you got it.
Sep 30, 2013 | Wenger Sport Elegance Chrono White Dial...
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
I'm able to set the time and date but once i push the crown back to its original place the watch doesn't start so i push the upper bumper and the seconds begin to run nevertheless the minutes never...
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
Jul 25, 2011 | Swiss Army Wenger Sportedge Bracelet Watch
How to set the time on an Elgin Anniversary clock
If there is no special winder for clock hands at the back of clock movement, you have to adjust time by lifting the dome and moving hands by finger. Move MINUTE HAND ONLY clockwise until the desired time is set. In no circumstance touch hour hand.
Feb 24, 2011 | Watches
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
My Elgin Steel PQS Chrongraph is not working. The minute hand stays in place and occasionally moves only to stop a half hour later. The second hand is functioning. I can not advance the minute hand with...
If the problem started immediately after you dropped it, then the impact is likely to have damaged it and a trip top the dealer is unavoidable.
Whatever the cause of your problem it is best left to watch repairer to sort it out.
Feb 10, 2010 | Watches
I've recently found an old Elgin pocketwatch (Hunter Case, 1904?)
If you wish to return this watch to a working condition you need to find a skilled watch repairer who is willing to take on a challenge.
It could prove to be very expensive is parts have to be made to replace anything that is worn out or broken.
Jan 05, 2010 | Elgin Circa 1904 Watch
What are the 3 inner dials for? How do I set them?
one of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Nov 09, 2009 | Rolex Daytona 116520 Wrist Watch
Minute hand and second hand
Sep 07, 2009 | Casio Watches
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
Dec 25, 2008 | Fossil CH2470 Watch
Watches Logo
49 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
