Question about Garden
John deer skidsteer 8875
Transmission charge pressure warning indicator light is on how do I fix it?
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
woobie dog
  • 1273 Answers
SOURCE: 318 jOHN dEERE WILL NOT CHARGE BATTERY.
Hello, W/D here.
The best place to start is to clean the terminals on the wires and lugs at the solenoid and battery. Shiney and bright is the rule.
Please repost or respond to this post so we can try more if necessary.
Best regards, --W/D--
Posted on Aug 16, 2009
jdlipscomb41
  • 157 Answers
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
Posted on Sep 18, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
My 15 amp switch fuse for my 250 skidsteer keeps burning up, what is this a symptom of?
Bare wire hitting metal, or what ever the switch runs it going bad
like a dead short in you lights.
Nov 07, 2013 | John Deere 240 250 SKID STEER TECHNICAL...
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
On a 2001 ford taurus what is the exclamatin point on the dash? The light comes on and goes off at times.
Hope this helps.
Item Part Number Description 1 — Instrument cluster 2 — Odometer reset shaft 3 — Air bag warning indicator 4 — RH turn signal indicator 5 — Charging system warning indicator 6 — Tachometer 7 — Low oil pressure warning indicator 8 — Brake system warning indicator 9 — Cruise control indicator 10 — Check fuel cap indicator 11 — Anti-lock brake system (ABS) warning indicator 12 — Check transmission indicator 13 — Odometer 14 — Transmission range selector indicator 15 — Trip odometer 16 — Theft indicator 17 — Low coolant indicator (if equipped) 18 — Safety belt warning indicator 19 — Low fuel warning indicator 20 — Fuel gauge 21 — Malfunction indicator lamp (MIL) 22 — Door ajar warning indicator 23 — Traction control indicator (if equipped) 24 — Engine coolant temperature gauge 25 — High beam indicator 26 — LH turn signal indicator 27 — Speedometer
Jun 05, 2010 | 2001 Ford Taurus
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
