Question about Microwave Ovens
Need cooktop replacement bulb for Kenmore
Need cooktop replacement bulb for Kenmore Microwave model 721.80824500. Need to know voltage and wattage so I can buy it locally.
    Sniper:
  • 52 Answers
Search the web site www.searspartsdirect.com Once you find the information, you can purchase it where ever you choose. If you found this information to be helpfull, please rate my solution. Thanks D. Lange
Posted on Apr 25, 2009
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
Where do I get replacement halogen blub
Hi Sandie
You are asking about a Microwave oven...right?
They usually don't use halogen bulbs. Just a standard incandescent bulb. Don't need super bright in Microwave oven.
Take the bulb out and note the Voltage, Wattage and Shape & Size of the base. Bayonet or Screw etc. some details may be stamped on bulb.
Replacements can be had from many sources. Hardware / Electronics... depends where you are.
If the bulb is halogen for a vehicle headlight for example... take original or photo to an automotive shop.
Good Luck
Apr 07, 2015 | Microwave Ovens
Why is cooktop light so hot on Kenmore Elite microwave hood combination
Check your owner's manual for the proper wattage bulb, and be sure NOT to exceed it.
Jun 27, 2014 | Kenmore Microwave Ovens
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
What wattage bulbs should be in the sharp model r-1610
According to the owner's manual (found online here) neither the interior nor cooktop bulbs should exceed 30 watts.
The original Sharp part number is RLMPTA068WRE0 if you'd like to order them.
You can get them Encompass here or Sears Parts Direct.
Jan 02, 2011 | Sharp Microwave Ovens
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
