Question about Maytag Washing Machines
Maytag washer model MVWC6ESWW1 will only spin. Won't fill or agitate.
  • 1294 Answers
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Posted on Jun 05, 2007
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
FixinFax
  • 3085 Answers
SOURCE: my maytag mod #mvwc6esww1 [bought refurbished
Yes, this is a normal function, the washer is actually figuring out the best way to wash the clothes.
Posted on Nov 25, 2009
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Jahn27
  • 1554 Answers
SOURCE: Maytag Centennial Washer model MVWC6ESWW1
It sounds like this is a clutch and brake assembly problem. The clutch spring must provide the necessary pressure for the lining to turn with the hub and the clutch tab to push the brake cam driver and release the brake. The clutch spring of your washer must be weak or the clutch lining is worn causing it to slide and not release the brake. This prevents the tab that holds the clutch spring to force the brake cam driver, release the brake, and allow the basket to spin particularly when the machine is under load. This is manifested in the spinning of the drum when the machine is empty. The clutch and brake assemblies are located just below the tub and the excessive heat resulted from the friction between the clutch lining and the clutch hub.
Remove the thrust washer from the agitator shaft then remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip using a screwdriver. Unsnap the clip and the clutch retaining ring the slide the clutch off the agitator shaft. Make sure to retain the washer located under the clutch.
Install the new clutch assembly on top of the gearcase then insert the clutch band and hold it in place. Using a pair of needle-nose pliers, place the end caps on the clutch spring and compress to insert into the open end of the band. Release the tension on the spring and the band will stay in place the reinsert the retaining clip on top of the clutch.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 30, 2011
Model MVWC6ESWW1. Why won't it fill?
Did you check the voltage to the water valves? If you don't have voltage then it maybe the control board.
Jun 07, 2015 | Maytag Washing Machines
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My maytag mod #mvwc6esww1 [bought refurbished
Nov 25, 2009 | Maytag Washing Machines
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
