Can roku 3 be connected to tv by dvi/hdcp connector
oakwoodman
  • 36 Answers
SOURCE: Apple TV and Sony KE32TS2 Plasma TV
That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
Posted on Sep 16, 2008
SOURCE: HDCP not compliant after hook up
We have hooked up our Sony HD TV Bravia Model KDL-46v5100. when we hook up the DVI connectores the message says not
HDCP not compliant, what does this mean???
Posted on Jan 01, 2010
  • 4 Answers
SOURCE: DVI Alert, your HDTV does not support HDCP. what
Ok so, I was having the same exact problem but I got mine to work.
Make sure you have your HDMI cable is connected from the TV and cable box....
1)Turn off your tv and reboot your cable box (my cable box was rebooted by pushing the following buttons AT THE SAME TIME: "info," "vol ," and "vol-").
2)Once your cable box reboots completely, power it and the TV on...
3)Push your INPUT button on the actual TV REMOTE. Give it a couple of seconds and then use your CABLE BOX REMOTE to begin switching the channels. Your HD channels will be in the 600's if you have the same cable company as I do.
Hope this helps...it worked for me
NOTE: Your COAXIAL should only be plugged in from the cable outlet on the wall to the cable box. Your HDMI cable will be the one to plug FROM the CABLE BOX to the TV
Posted on Sep 14, 2010
taran_2005
  • 10515 Answers
SOURCE: Does NEC plasmasync 42MP2 support
HDCP stand for High-bandwidth Digital Content Protection. It's a way to ensure protection from content piracy at the output on digital connection (that is why component work, as it's analog and not subject to this like some DVI cable or all HDMI and Dipslay Port cable).
The way it protect the data is a bit like for a securized internet connection, using encryption key.
To be able to circumvent this, you need a "HDCP Stripper".
It was invented by Intel and started to appear in 2003 on HDMI cable and (version 1.1 of HDCP) and a bit before that for DVI.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 09, 2010
SD Tech
  • 14553 Answers
SOURCE: How to connect my pc to my tv (my pc has a DVI connector while my tv has a HDMI and RGB connector)
You might want to search to see if adapter for dvi to hdmi etc.
Posted on Mar 19, 2012
Playing blue ray movies on jvc dla sx21 projector
It should work right away. Try again, restart the projector and ps3 make sure everything is connected and the input on the projector is on dvi.
May 17, 2008 | JVC DLA-SX21U Multimedia Projector
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
How do you connect roku to a tv without an hdmi plug
component adapter? If your TV has a connection for DVI or VGA, you can purchase adapters that will change the HDMI to DVI/VGA if needed. Check online or go to radio shack
Jul 25, 2014 | Roku Streaming Stick
How do I connect my iMac 27" i7
You can buy an optional cable that you can plug into the mini-DVI or mini-displayport port at the back of your iMac.see example picture on: http://www.ecoustics.com/electronics/products/new/570842.jpgFirst you need to be sure to know exact if you have a mini-DVI or mini-displayport. The connectors are different and depend on how old your iMac is. Than you can buy the connector that fits your Mac. The you only need to check the connections on your TV. HDMI or DVI will give the best image quality. VGA is older and will result in a lower image quality. Last, you need to buy a cable between the adapter and your TV.
Jun 12, 2012 | Apple iMac Z0GF0005F Desktop
Hi. I have a BluRay problem. I have an ASUS internal BluRay player, an Nvidia GTX 275 graphics card and a Samsung RZ2233 monitor. The Nvidia Control Panel indicates that the graphics card and monitor are...
I had to look this one up and here are a few suggestions to possibly solve your problem.
1. The monitor is capable of 120hz, however, as I understand it, blu-ray players are capable of 60hz which in some cases has led to cause issues with some movies, players and the tv/monitor's they are connected to.
There have been reports that by changing the Hz from 120>60, that capability issues similar to these have been resolved.
2. Contact customer support for the HD software you're using and let them know of the error code # you're receiving. There could be a bug that is causing this to happen or perhaps an update to the software that can correct it.
3. Being that your monitor, video card and blu-ray drive are HDCP-compliant, the only logical step would be to replace the DVI cable to something that explicitly states HDCP-compatibility.
Aug 10, 2010 | ASUS Computers & Internet
DVI alert, Your HD tv does not support HDCP, disconnect your HDMI connector and connect the YBbr connector
Antipiracy warning , cannot be disabled or bypassed, it's a part of your tv. Because of it you will not be able to use the DVI connector to view blu-ray movies. You will have to use the Component (YPbPr) ones , at a much lower image quality.
Mar 20, 2010 | Televison & Video
Dec 31, 2009 | Sony Televison & Video
Blue-ray Player HDMI jack to existing TV DVI-HDTV connector
Unless your TV is HDCP compliant (sorry, don't have to research this for you), you may not be able to watch Blu-Ray movies from your Blue-Ray player in 1080p. So first find out if your TV can do HDCP via the DVI port (i doubt it). If it can, you can get an HDMI-to-DVI adapter (you can find them real cheap off Amazon.com)
-Eddie V.
Dec 31, 2008 | Denon AVR-485 Receiver
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
