Error code EF2 on Electrolux model EWF14811 washing machine
3 Suggested Answers
devdeep dhar
  • 375 Answers
SOURCE: Error code ed1 on electrolux ewx14540w washer/dryer
The description of Ef 2 is told as error caused of excessive Detergent. Sir, Please consult another expert seperately for code Ed1. To tell, this error code is not described by anyone.
Thank you Sir, Have a nice day.
Posted on Sep 21, 2009
erick69ha
SOURCE: EF 2 error is showing
it means that your using too much soap in your washer... the service manuel recommends that you reduce the amount of soap you are using.
Posted on Dec 18, 2012
Electrolux washing machine showing error 33(no interlock). what do I do?thanks
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
Dec 04, 2015 | Electrolux Washing Machines
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
I have an Electrolux ewf14811 washing machine the handle has broken and I need to open. Any suggestions
yes
you need too pull the machine out
and take the two screws out each side of the top plate
slide the top plate too the front and lift it off
with the main power removed !!!
reach down to the door catch you easily lift the peg clear
if you just with you knee push the door in a little
so this way youll be able too edge the door out
and recover your washing
i think the motor has failed for spin
or the filters are blocks on the pump side
or the pump has failed
perhaps a wire from clothing or a coin has jammed its viens up
so clean the pump usually there is an access too it
from the front panels
if your not sure then ask a tech for help
will cost like no more than £30 uk dont pay more
Mar 05, 2015 | Electrolux Washing Machines
Hi i have Electrolux washing machine model EWF14811 the display is not working what can i do ?
I've never seen a model EWF14811 so I believe that it is a EWF1481 model washing machines.
Unfortunately, you have to replace the entire electronics because the LCD display is part of the PCB.
Also, before replacing I suggest you to check contacts on the LCD display which can be weakened by moisture,... etc.
Dado
Feb 19, 2015 | Electrolux Washing Machines
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Sep 13, 2014 | Electrolux Washing Machines
What is the ef2 error code
Good Afternoon Friend,
I understand you are receiving an EF2 error code on your Frigidaire washer, model# GLTF2940ES. The EF2 code states that too much soap was used. I suggest running a cycle without any soap and any clothes in it. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire GLTF2940ES Front Load Washer
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
EF 2 error is showing on my electrolux EWF14811 washing machine what does this mean?
Aug 15, 2011 | Electrolux Washing Machines
Sep 21, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
