Question about NetGear WGR614 Wireless Router
Nat help i play xbox live but its hard for me to find games because my NAT is on strict i want to open it but last time i did my internet on my pc's went down to????
  • 728 Answers
Hi jman92592,
Here are some options with that router. Some online games and videoconferencing applications are incompatible with NAT. The WGR614 router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default in the PORTS Menu. If one local PC acts as a game or videoconferencing host, enter its IP address as the default
To set up an additional computer to play games like Half Life, KALI or Quake III:
1.Click the button of an unused port in the table.
2.Select the game again from the Service Name list.
3.Change the beginning port number in the Start Port box. For these games, use the supplied number in the default listing and add +1 for each additional computer. For example, if you've already configured one computer to play Hexen II (using port 26900), the second computer's port number would be 26901, and the third computer would be 26902.
4.Type the same port number in the End Port box that you typed in the Start Port box.
5.Type the IP address of the additional computer in the Server IP Address box.
6.Click Apply
The WAN Setup options let you configure a DMZ server, change the MTU size and enable the router to respond to a Ping on the WAN port.
Connect Automatically, as Required
  • Normally, this option should be Enabled, so that an Internet connection will be made automatically, whenever Internet-bound traffic is detected. In locations where Internet access is billed by the minute, if this causes high connection costs, you can disable this setting.
  • If disabled, you must connect manually, using the sub-screen accessed from the Router Status menu "Show WAN Status" screen.
•Disable SPI Firewall
  • Normally, this option should be Enabled, so that your local network will be protected by the Stateful Packet Inspection (SPI) firewall included in the WGR614. However, certain communications functions like VPN may require turning off the SPI feature.
Setting Up a Default DMZ Server
  • The default DMZ server feature is helpful when using some online games and videoconferencing applications that are incompatible with NAT. The router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default DMZ server.
Note: DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall, and is exposed to exploits from the Internet. If compromised, the DMZ server can be used to attack your network.
The WAN Setup menu, shown below lets you configure a Default DMZ Server.
  • To assign a computer or server to be a Default DMZ server, follow these steps:
1.Click WAN Setup link on the Advanced section of the main menu.
2.Type the IP address for that server. To remove the default DMZ server, replace the IP address numbers with all zeros.
3.Click Apply.
Good Luck and don't forget to leave a rating.
Thanks Mark
Posted on Apr 23, 2009
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
maybe instead of nat, set you xbox as a DMZ host. This would be done on the router itself. It will allow the Xbox to bypass the firewall and nat on the router/gateway, and at the same time keep your computer safe.
Apr 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need to make NAT settings to open for xbox live.
Open up your internet explorer then go to tools then internet options then make the changes nessessary i would recommend you go to google on what to change specificly
Mar 23, 2009 | Arris SBG1000 Wireless Cable Modem Gateway...
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
- Try to use admin for username and password field
Mar 11, 2009 | NetGear WGR614 Wireless Router
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Strict NAT?
If you call microsoft, and tell them that your NAT is strict, they will tell you specific ports you will need to forward. (For Free). If you arent sure how to forward ports, call up your routers manuafturer, or send me another message. I have forwarded my ports as well.
Apr 20, 2008 | Belkin Wireless-N Wireless Router with...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
NetGear WGR614 Wireless Router Logo
186 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
