Question about Garden
Yellow needles in group like a bleach spot lower branch
Washing machine bleaching colored clothes by mistake
thanks for the question its possible that the bleach disp is clogged and when its suppose to release the bleach some stays hehind and theres still some left over from the last load i would check that thanks the appliance doc
Sep 16, 2008 | Washing Machines
What the branch name and branch code of Absa bank that is situated in Bizana?
Absa Bank, Central, Bizana ' Snupit.co.za
www.snupit.co.za/bizana/central/absa-bank/330566
  1. Cached
Absa Bank is located at Bizana Shopping Centre Square, Corner Hope Street & Upper Main Street Central, Bizana. Contact 039 251 ****. View the latest reviews ...
Absa Bank Bizana - Address, Phone, Fax, SWIFT, PAN, Opening ...
www.bankspedia.com/Banks-in-SouthAfrica/Absa-Bank/Bizana-Branch-1-5353.html
  1. Cached
The Absa Group Limited (Absa), listed on the JSE Limited, is one of South Africa's largest financial services groups offering a complete range of banking, ... Absa bank that is situated in Bizana Google Search
Nov 15, 2016 | Computers & Internet
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
I have a 15-20 ft. pine tree. We recently trimmed alot off the bottom of it and now the healthy branches on the tree are turning brown. Is my tree dying?
Pine trees seal themselves with sap fairly quick so you don't have to worry. If the needles are turning yellow and dropping it could be experiencing some shock or it may just be dropping needles for the fall.
If the needles are actually turning brown, check the trunk and branches for signs of boring insect damage such as hole with sap coming out.
Oct 27, 2015 | Cars & Trucks
How do we avoid the spotting; seems like detergent is not completely dissolving; liquid
do you have a water softener sometimes they put too much salt in .
Sep 23, 2015 | Kenmore Washing Machines
What is a group of trees
Huh, ...?
i thought a 'group' of tree's, was a - FOREST!
Apr 14, 2015 | Computers & Internet
Needle keeps hitting bobbin case when trying to pull it up to top
If the needle is hitting at the low spot when its lowered, the needle is bent or not fully pushed up into the needle bar, could be timing of the needle bar as well.
Jan 15, 2011 | Janome 4052LX Mechanical Sewing Machine
The next wash, after a wash load using bleach, gets a few bleach spots. After washing a load using bleach, I've tried washing a load which would not matter if bleach contaminated it. Even the 2nd load,...
I would just put the bleach into the tub while it's filling and wait till it's about half full of water before adding the clothes.
It may help to pour the bleach into the dispenser then pour water in after it to rinse it out. Some washers say to do this in the manual.
Dec 07, 2010 | Washing Machines
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
