Question about RTO Reebok CS-1 Pedometer
Lifesource h215 I put in a new battery, all the lights are on, I adjusted time, etc., but it does not register any steps when I use it to walk or run (as I have for the past 2 years). Ed
Cuff doesn't inflate lifesource ua767 bp monitor. How do I reset or fix this? Have brand new batteries.
Inflating a Blood Pressure Cuff - YouTube
? 1:01
www.youtube.com/watch?v=8e6qtnHa8ps
Sep 30, 2008 - Uploaded by expertvillage When you take a blood pressure reading it is important to inflatethe blood pressure cuff until you no longer ...
Sep 24, 2015 | Lifesource Health & Beauty
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    ADDING HANDSET SAYS OUT OF RANGE
    A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
    1. Remove battery
    2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
    3. Screen will be blank. Immediately press the right soft menu button.
    4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
    5. Remove battery (yes again)
    6. Reinsert battery (this time there's no need to hold down any buttons)
    7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
    8. Place handset on base and it will register as normal
    Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
    Operator manual for lifesource pedometer H-215
    pacificrimwellness.com/library/.../H215-Pedometer_Manual_ENGL.p.
    Jun 10, 2009 | RTO Reebok CS-1 Pedometer
    No instruction manual for a LifeSource chest/wristwatch monitor -
    Not sure that you are talking about a blood pressure monitor or a heart rate monitor.
    The blood pressure monitor that you listed as the device you are asking about the manual is here
    http://www.lifesourceonline.com/and_med.nsf/html/WEBB6FKQFC/$FILE/UA767Plus.pdf
    if you are talking about a heart rate monitor , which it sounds like because those have watches and chest bands that is something different. i would need to know what kind of heart rate monitor it is. A few tips on the devices, you will need to dampen the contacts on the band, make sure you place it in direct contact with your skin, under your pectoral muscle, if you are female then it goes under your sports bra band. i always reccomend jumping on a machine for a little warm up then starting the watch.
    I noticed you said that you changed the battery i hope you sent the watch in to the manufacturer to change, sometimes it comes out ok but alot of times it doesn't work there are sensative devices in the watch that can get messed up very easily.
    Jan 12, 2009 | Lifesource One Step Plus Memory Blood...
    Harmony 890 Freezes
    I called Tech Support, and they walked me through a firmware upgrade, and an update.
    Step 1. Hold down "OFF" button, and remove the battery. Step 2. While holding "OFF" put battery back in. Remote will now enter "Safe Mode"
    Step 3. Plug Remote into USB. Step 4. Go to Support -> Downloads -> Firmware from the app. It should update the firmware.
    Run the update again, but this time, the only thing I did differently was plug in the remote on the screen whic said: "Done updating Extender, remote to be updated next" rather then the next one. The update went through this time.
    Jan 07, 2009 | Logitech Harmony 890 LCD Remote Control
    Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
    To deregister ALL handsets:
    Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
    Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
    Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
    Step 4: All handsets will show NOT REGISTERED.
    To register a handset (register 1 handset at a time):
    Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
    Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
    After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
    REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
    Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
    IF deregistering does not work .. you will need to reset the entire system
    Step 1: Disconnect the power to the telephone base.
    Step 2: Disconnect the handset battery.
    Step 3: Wait a few minutes and then reconnect the power to the telephone base.
    Step 4: Reconnect the handset battery
    Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
    You will need to set the time and date again after resetting the entire system.
    Mar 11, 2008 | Lands Phones
    Registering a new phone
    With a little searching I was not able to confirm this phone could handle more than one cordless handset. Are you replacing a defective handset or trying to add a second. If adding, do you know if it can handle the second unit (is it advertised on the box, in the user guide, etc?) If replacing, you most likely have to de-register the old handset on the base unit before you can register a new one. If you are adding, try de-registering the working handset anyway and registering the new one. If the new one registers and you cannot re-register the once working phone you will know either the system cannot handle two phones or (if the new one will not register but you can again re-register the original) that the new handset has a problem and should be returned.
    Jul 10, 2007 | Uniden Cordless Phone
    RTO Reebok CS-1 Pedometer Logo
    60 people viewed this question
    Top RTO Exercise & Fitness Experts
    Howard
    Howard
    Jax Planet
    Jax Planet
    Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
