Question about Toshiba Satellite M30-S350 Notebook
Problems with M30
Laptop is slower at responding. battery not holding a charge like it used to....couple of hours now it is critical low after 10-20 minutes. AC cord gets very hot. any suggestions. ( I already had it in no viruses or bugs..never have had any..they did registry clean up etc.)
    Sergeant:
  • 457 Answers
Replace the battery replace the adapter and all will be find..
Posted on Sep 25, 2007
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
Toshiba Laptop L25-s119 will not work under household power.
Is this a new laptop ?
Your battery may need replacement!
Dec 21, 2009 | Toshiba Satellite L25-S119 Notebook
I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash. This happens regardless of whether I have it plugged in or not. What does that mean?
This means your battery charge is critically low. It's also a sign that your battery is no longer holding a significant charge and is a good time to replace the battery.
Nov 25, 2009 | Dell Latitude D430N Notebook
MY Laptop battery , Adapter or Motherboard
Did you buy an adapter that matches the same voltage and amperage values as your original?
Jan 11, 2008 | Acer Aspire 3100-1405 Notebook
My pentax optio M30 turns off after it's on...
Pentax Tech Support will have the remedy- this is where to answer lays- there is no user remedy.
Jul 10, 2007 | Pentax Optio M30 Digital Camera
Toshiba Satellite M30-S350 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
