Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG front load WM2801HLA code FE - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
5 Suggested Answers
SOURCE: LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Posted on May 28, 2009
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
SOURCE: LG front load washing machine
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Posted on Apr 26, 2011
ksflash
  • 19 Answers
SOURCE: lg wm2801hla starts fill with water but that it it gives a humming noise
What age is it?
My guess is that the solenoid valve is malfunctioning. They are usually pilot operated, so they usually shut off on failure.
Posted on Oct 03, 2012
I'm getting FE code on LG WM2101H front load washing machine. What should I do to repair it?
Most likely the "hall" sensor. The motor position sensor. Pretty easy fix. Part is under $20. Check out appliancepartspros.com or repairclinic.com for how to videos.
Nov 14, 2016 | LG WM2101H Front Load Washer
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Mar 01, 2014 | LG WM-2077C Front Load Washer
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
Lg wm2801hla starts fill with water but that it it gives a humming noise
What age is it?
Oct 03, 2012 | LG Wm2801hFront Load Washer wm2801hla
LG front load washing machine WM2233H Error code is FE
Thank you,
Shawn"
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
FE ERROR CODE
FE error is due to "Over flow" error. Water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. Water level sensor needs to be replaced.
Apr 09, 2010 | LG WM0642H Front Load
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Washing Machines Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
