Where are the audio output transmitters on a pioneer stereo model RX-590
tech48
  • 624 Answers
SOURCE: Pioneer car stereo output Ic's
In most cases the problem is the electronic volume IC, ref # IC151 and part number PLM003AM (in the DEH-1600). It is a different part number and ref # in other models.
It is not always this part that causes the failure, sometimes it can be the muting transistor, a voltage regulator or even the micro on more rare occasions. It will require some troubleshooting to figure out exactly what part it needs. You will need to have an O-scope to trace down the audio signal and follow it from one pin to another. You also need a multimeter to check a few voltages in the radio. All of this must be done on a test bench with the radio powered on with a power supply. If you do not have these tools, you will not be able to figure it out for certain, you would only be taking a stab in the dark. That can get rather frustrating and even expensive buying parts that do not fix the problem.
The electronic volume IC is a flat pack surface mounted component and requires the very best soldering skills to be able to replace. It is very easy to do damage to the circuit board that can not be repaired if it is not done perfectly. If you have not replaced these type of components before, you should not even attempt this repair.
If you would like the service manual I can sell you the PDF format of it for $10. I also have the service manuals for most Pioneer products as well as Kenwoods, JVC, Panasonic, Denon, Marantz, Clarion, and more. Let me know if you would like to get it. The service manual is very helpful in repairing electronics. It contains the schematics and parts list which is vital to make sure you get the right parts and to be able to trace down any signals and to know what parts are doing wha, and to figuring out if the voltages are correct.
I hope this helps,
Dave
I hope this helps
Posted on Nov 18, 2008
anasmaq
  • 100 Answers
SOURCE: wireless speakers to audio devices having no audio output
you can find all kinds of adapters for RCA or phone jack to anytype of connectors at best buy or circuit city, if not Radioshak probably have them. just ask for a cable adapter to the type of connector transformation you need for the speakers.
Posted on Dec 30, 2008
  • 4234 Answers
SOURCE: have a pioneer stereo model rx570 and the outputs
Remove the outputs completely and start up the unit. Measure each of the pads to ground with a DC voltmeter and report the values here. I suspect that you have either an open driver transistors. Using the voltage readings, I should be able to guide you further.
Dan
Posted on Feb 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: Stereo cuts out at half volume.
You don't exactly define what "cuts out" means.... silence, protection or power off?
What makes you think it's thermal in nature?
Have you considered the speaker load impedance may be too low for the amp?
Posted on May 02, 2010
Testimonial: "Impedance was the problem I hooked up the speakers parallel and it fixed the problem."
gopakumarg43
  • 74251 Answers
SOURCE: WHAT OUTPUTS DO I USE FOR AUDIO OUTPUTS TO MY
Connect the audio out sockets at the TV, to Audio In sockets at the stereo, using an av cable.
Posted on Oct 02, 2013
Been trying to get the radio station to program.it hasn't been working. On my RX-590
If you are using automatic channel search, disable it and use manual tuning to find the station then program it. If the signal you are seeking is comparatively weak compared to others, the tuner will skip it in the automatic search mode.
Oct 20, 2013 | Pioneer Rx-590 Home Stereo Double Cassette...
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
May 02, 2010 | Audio Players & Recorders
How to hookup an IPOD to a pioneer avh-p6500 car stereo
If your car stero has a stereo audio input connector then you can plug a cable in the headphone on the IPod and the other end of the cable into the stereo audio input on the car stereo.
If you don't have an stereo input on the car stereo then you can buy a FM transmitter that is powered by the car's cigarette socket, connect the IPod to the transmitter, switch on the car radio and tune it to the FM station that matches the FM transmitter.
You can now listen to your IPod from the car radio.
Jan 26, 2009 | Pioneer AVH-P6500DVD Car DVD Player
I have a pioneer Rx-570 stereo the fuse blowout i replaced the same fuse but blowout again I wounder what is the cause for it
hello my friend you have a short in the output ckt,also check the power supply for any damage(shorted) components. like diodes,caps,transistor.
but your main concern should be the audio output circuit.
caypianan@yahoo.com
Nov 07, 2008 | Pioneer Audio Players & Recorders
IPod connection
ipod...^.^ you can use a fm transmitter that you can buy from an ipod store, or you can use a audio cable ussually used in audio- video connection to a television set or hdtv sets. if you are trying to use a tape input-output, try it first in some devices. such as an cd player or walkman. if these works in two speakers maybe the plug is not compatible to your ipod. or maybe you bought an mono tape input-output instead or stereo type.
you can see if its an mono or stereo, by looking at the plug if it has two black lines it is an stereo if it's just one, that is mono.
hope I helped you with your problem..
Jul 12, 2008 | JVC RX-554V Receiver
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
64 people viewed this question
 Grubhead
Grubhead
