Question about Radio Communications
Why does Sidewinder 46 transceiver not pick up any talking?
Old mark sidewinder 46 transceiver. connected to a swiss style antenna. powers up fine. cant hear anyone talking on am, lsb or usb
SOURCE: Will nthe sidewinder precision pro work with XP?
yes you need version 3.0 or later for it to work.
Posted on Dec 03, 2007
Mechanic688
  • 204 Answers
SOURCE: No am power
Radio dude, What you have is a blown am regulator. The sideband side does not use the mentioned transistor. They use a few different numbers here for the am regulator. One of them is a 2sc1419. On the Uniden Grant they put the transistor on the rear right above the antenna jack. On the 148 they put the transistor back in the right rear of the radio as your looking inside on the speaker side. Fixing it includes unsoldering the transistor and purchasing a replacement and resoldering it back in. This transistor is bolted to the side rail in the rear. I usually use a ECG152 as a replacement. It's not unusual to blow this one if the radio has been tuned. Let me know if your comfortable swapping it out. Otherwise it needs to go to a shop with a decent tech that won't take you to the cleaners. Let me know,, Mechanic
Posted on Feb 21, 2008
  • 67 Answers
SOURCE: cant hear anyone
Is the squelch off? Is there even a crackle from the speaker? Does it appear to go into transmit?
If you have a friend can listen in while you try transmitting, get him to let you know if voice can be heard, or a carrier appears (on AM). If TX OK, try sideband, if OK, look for faulty speaker/ socket/ wiring. If no audio on TX, suspect the audio amp is bad.
Posted on May 25, 2008
Mechanic688
  • 204 Answers
SOURCE: wont talk out.
Hey, stubby, Turn you mic gain wide open on the radio. That controls the modulation. Course if the radio has not been tuned that makes a big difference. Also the size of the antenna and how well it's tuned makes a big difference. Mechanic
Posted on Nov 05, 2008
ginko
  • 19396 Answers
SOURCE: drivers for windows vista 64 bit
I am sorry, but I have to tell you that the Sidewinder II is not Vista 64 bit compatible.
Here Microsoft page for Vista compatibility, when they say unknown it means it does not work on Vista 64.
I hope this can save you some time.
Posted on Apr 10, 2009
I have the Bernina Artista 180. It is not recognizing when I turn the bobbin winder on. Any suggestions?
For a quick fix and until you can get your machine serviced, pick up a Sidewinder bobbin winder (check to make sure your bobbins will work since the larger Bernina bobbins may not). I purchased a Sidewinder a few years ago and use it all the time. Saves wear-n-tear on the machine but also lets you quickly wind multiple bobbins without having to unthread your machine. Most Sidewinders are battery operated, but mine also has an AC adaptor for electrical usage too.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Sep 24, 2017 | Bernina Sewing Machines
Bobbin winder not working
For ~$30, you can purchase a stand-alone bobbin winder (Sidewinder) that you can use to wind your bobbins. Saves wear-n-tear on your machine and you can wind bobbins without unthreading your machine. Just be sure to verify your bobbins are compatible with the Sidewinder.
Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Bobbin Winder
Jul 18, 2017 | Sewing Machines
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Jul 16, 2017 | Singer Sewing Machines
I need to buy a power supply for a sidewinder force feedback wheel. where do i get one help
I suggest you buy it now. It is very rear to find
http://www.ioffer.com/i/x03-73497-microsoft-adapter-ac-cord-12v-1-3a-sidewinder-189530392
Please rate 4 stars if this is what you were looking for.
Apr 25, 2011 | Microsoft SideWinder Precision Racing...
I have a Sidewinder 3D Joystick with the old standard gameport 15-pin connector. I bought a new motherboard that didn't come with a gameport, so I bought a PCI soundcard with a gameport incorporated. I...
Make sure you get the latest drivers for your soundcard. The drivers will include the software for the joystick port so its recognized properly by windows. Also you may want to go to the support page for your soundcard to see if any settings would need to be changed as well.
Sep 22, 2010 | Microsoft SideWinder 3D Pro 2.0...
I need a power supply for a Sidewinder Wheel and Pedals set. Where can i get one?
I would check amazon.com and ebay.com and if those don't have it I would check the company website. :)
Jun 02, 2010 | Microsoft SideWinder Force Feedback Wheel...
My sidewiner worked fine with xp now new computer
You need the USB adapter if you want to use it in Vista. They are very hard to come by, as most of them don't seem to be compatible with any of the Sidewinder products. This is your only option and not guaranteed. The adapters are about £10.
Apr 05, 2009 | Microsoft SideWinder Force Feedback Pro...
The Software
I have same stick, that same software wont work with xp or vista depending on what game you have you should be able to set up in input settings for the game , there was a patch at one time that someone made up you mite want to try here and do a search > http://forums.ubi.com/eve/ubb.x?a=frm&s=400102&f=49310655
Grazz.
May 18, 2008 | Microsoft SideWinder Force Feedback 2...
Not connected
Download the correct drivers for it that fit your operating system. Install them and away you go. Type into Google "Microsoft sidewinder drivers"..download and follow on-screen instructions to install them
Dec 09, 2007 | Microsoft SideWinder Precision Pro 2.0...
Radio Communications Logo
62 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
