Question about Sharp Carousel Microwave Ovens
My sharp carousel model no. R-9X56 has just died after 18 years of functioning perfectly. I would like to replace with a similar model, but one of the features I loved about this microwave was the pull down door (as opposed to a swinging door). What model is the closest fit to replace it with specification wise?
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
William E. Miller
prototech@usa.net
Posted on Dec 13, 2008
  • 178 Answers
SOURCE: How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Posted on Sep 11, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Posted on Feb 02, 2010
Testimonial: "Thank you. I will check it out and then decide whether to repair or replace."
Looking to replace glass turntable for Sharp Carousel Microwave model R -4840. Please assist with the current item number and price.
Check with www.microwaveglasstrays.com (Martin Microwave Inc.) 1-877-894-0035
The original replacement tray (Sharp part # NTNT-0048MRF0) has been out of production for years and nothing else will fit, however, Martin may have a used replacement. If they don't have it, no one will!
Nov 09, 2010 | Sharp Microwave Ovens
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
My Sharp Carousel R405HW is not producing heat but all the other functions are working and it is on high heat power level wise.
sounds like the magnetron or transformer may have died, take to approved dealer, if worth it!
Sep 29, 2009 | Sharp Microwave Ovens
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
My Sharp Carousel Model R-370E No time display
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
If you decide to send yours in for repair, here is the info you need:
We have a service / repair manual for a similar model and have uploaded it to our site here to help you.
It should be similar enough to give you safety info and similar step by step help in disassembly info.
Most computers will open this document automatically, but you may need the free Adobe Reader.
We would really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the attached sample photos.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Jun 14, 2009 | Sharp Microwave Ovens
Sharp Carousel 2 Microwave start switch broken
Hi George,
I ahve the same issue. Did you manage to repair it or did you need replacement?
If repaired then how?
if replaced then where did you manage to get the part from?
Regards
Vipin
Jun 04, 2009 | Sharp R-1870 Convection/Microwave Oven
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Control Panel for Sharp Carousel Microwave Oven
would you help me to find..
driver Acer Nplify 802.11b/g/Draft-N WLAN
May 07, 2009 | Sharp Microwave Ovens
LCD light does not come on
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Although you may decide that it is more economical to replace the oven.
Feel free to contact me directly (and please remind me of your full model number) if you're interested in repair.
William E. Miller
prototech@usa.net
Mar 04, 2009 | Sharp Microwave Ovens
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
Sharp Carousel Microwave Ovens Logo
49 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
