Question about Carrier Heating & Cooling
I have an LG Split System Air Conditioner Model LSM304H-1 and the remote seems dead. If the reset button is pushed the panel lights up with all symbols but the on/off button does nothing. The screen on the remote is blank. New batteries have been installed.
SOURCE: air conditioner
NO GAS
Posted on May 13, 2007
bobotfel
  • 236 Answers
SOURCE: Sanyo 12KS71 Split Air Conditioner
Check your remote control the timer may be activated. Or try to push the reset button on your remote control to set it to default setting or just pull out the battery then insert it again then try. If problem persist then qualified technician is needed.
Posted on Jan 15, 2008
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
here are some icon meaning, this may help.
Posted on Apr 28, 2008
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
  • 17 Answers
SOURCE: My Ruud Air Conditioner Model UAMB-048JAZ is not blowing cool air
3 things it could be:
#1 problem with AC units - dirty coils, this leads to many other problems and is caused by neglecting to change filters monthly. You can buy coil cleaner commercially, but it is not the coils you see that get dirty. There is another set inside that is usually not visible. If you look outside and your unit is "iced up" there is a 98% chance that is your problem. Sometimes it could be iced and you can't see it from the outside. Solution, turn AC off and blow fan to thaw. When thawed, clean coils with coil cleaner and coil comb.
Relay switches, you already pushed it so you may have a bad switch.
These are the two most common problems. A mechanic will be quickl to say it is your compressor for $. There are normally only half a dozen things that go wrong if your AC is 10yrs or less. If it is over that, it could possibly have a more serious problem. (Secret hint - I have known AC's to last 30+ years if the filters are changed regularly. Letting dust and dirt build up on coils invites a host of other problems due to the stress it puts on the other components.
Posted on Aug 30, 2009
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
LGF122CS mini split will not turn off by remote, have checked with another remote, same problem however, fan speed lowers when the off button is pushed on the remote. operates properly by pushing the...
thats why there is a reset button somewhere at the back of the remote and some times under the batters remover the remote control battery cover remove the batters find the rest it will looks like a tiny hole you will have to press it with a needle insert batters back enjoy cold air
May 23, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
