DOG CHEWED THE THERMOSTAT WIRE RUNNING FROM THE HOUSE TO THE AIR CONDITIONER UNIT
    Novelist:
  • 189 Answers
Sometimes you can just turn off the power and cut out the bad spot and strip back the outer casing, match the colors and wire nut it back together. You need to be careful so that the new connection is not accessable to the bad weather. If you cannot protect the wire from the wet weather you should just replace the wire by running new.
Posted on Apr 23, 2009
Furnice air blows, but my ac unit outside want cut on
if the inside unit is running but the outside unit isn't - I would check the fuses or breaker. I suspect you have a blown fuse or a tripped breaker.
What is also possible is that the 'low voltage' thermostat wire (coming from the thermostat inside the house) has been cut - possibly by a lawn mower or weed eater - or chewed into by a dog.
If this is the case - you easily splice (with all power off) the wires back together using the color of the individual wires.
Jun 06, 2011 | Heating & Cooling
Outside unit won't come on. Drain pas appears dry/.
if nothing comes on (on the outside unit) when you turn on AC (and the inside unit runs ok) I would check the fuses and/or the breaker for the outside unit. I would suspect a fuse blown or a breaker tripped. It's also possible that your 'low voltage' (24V) thermostat wire has been cut (by lawn mower) or chewed into (by dog). If the problem is the low voltage wire you can easily splice it back together - just be sure all power is off.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
My dog chewed the thermostat wire by the compressor, i replaced the chewed wire now the thermostat won't turn on, therefore; no ac.. could it have blown a fuse? if so, where are they?
Either you have blown the low voltage fuse located inside the air handler (if there is one) or you have blown the transformer feeding the low voltage control wiring.
If the transformer is blown due to no fuse installed, I would recommend installing a low voltage 3A fuse in line with the red terminal coming off the transformer. This will protect the transformer in the future.
Aug 01, 2010 | Goodman CKL42AR42 Air Conditioner
The dog chewed the wiring to the condesor outside. i re wired and now the furnace turns on but not the a/c unit ouside?
Hi, well you have 1/2 of it right. Recheck the wiring and wire it color to color as you are not getting 24 volts to the condenser. If you have a gas furnace and not a heat pump you will only need 2- wires to run the outdoor unit, red and yellow. Make sure the dog didn't chew through another section also.
Shastalaker7
Jun 29, 2010 | Goodman CKL24AR24 Air Conditioner
My dog chewed through a group of multi-colored wires on my AC outside. Is there any way that i can fix this?
HI there well i think what you dog chewed on was the thermostat wires. if you tell me the colors maybe i can help you out.
ordonez305@aol.com
This is my e-mail
Jun 03, 2010 | Ruud UBHC Air Conditioner
My dog yanked a brown wire out of the outdoor ac unit that has the fan. how do i rewire it?
If it is the small wire, that goes to the coil on the contactor. It is a low voltage wire that comes from the thermostat. You need to disconnect power from the machine before attempting any repairs. Do not short the small wires or that could fry the transformer
On each side of the contactor is spade connections to the 24 volt coil. All machines use a magnetic contactor as a way to energize the machines parts using smaller wires coming from inside the house at the thermostat and inside blower.
Apr 19, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Thermostat wires running from house to outside Kenmore AC unit were chewed by dog. Got replacement wire. Took panel off. There were three encased wires running into AC unit that were chewed. Only see...
If you have a central air conditioner, or a split system, where the indoor unit is attached to the furnace and a outdoor unit is located outside of the home. 2 copper lines will be connected to it, a larger and a smaller one. If it is a air conditioner and not a heat pump, the A/C usually uses 2 wires, that are connected. Allot of times a installer will use a 3 wire thermostat wire, to run to the outdoor unit, if this is the case, the third wire will be folded back out of the way.
The color of the wire is usually picked by the installer, I myself usually use white and red and fold the green out of the way. If you only had 2 wires hooked to it to start with, it really would not make a differace which one you hook up to either one of the yellow wires.
All you are doing it having one wire coming in and one wire leaving,,,, just creating a complete circuit, just don't connect the two yellow wires together.
Example: If you have 2 yellow wires on the A/C unit and 2 wires coming from the house "example a red and a white" hook the white to "One yellow wire" and the red wire to "the other yellow wire".
You are just creating a complete circuit, when the thermostat calls for cooling, it creates a magnetic pull and closes the contact points, in the air conditioner, outside, this allows the 220 volt to flow to the compressor,,, and ahhhh cooling!
I hope I have not confused you, I am just starting to help on this site and still trying to make things understandable.
Wish you the best,
Paul Gibson
Mar 29, 2010 | Heating & Cooling
I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Jul 14, 2009 | Ruud UBHC Air Conditioner
AC unit fan won't turn
Yes those are the Thermostat Wires to the Unit Reconnect and you should be Fine.
Thanks
Please Rate me
George
Apr 26, 2009 | Dometic Rooftop RV Air Conditioner
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
