Question about Astatic Vs7 Noise Canceling External Cb Speaker
Its got two plugs a red one and a black one which color plugs into the ext and pa?
2 Suggested Answers
  • 1137 Answers
SOURCE: Does anybody know the wiring sequance that you
Its not in my area of expertise but maybe this link will have some info:http://www.dxzone.com/catalog/Technical_Reference/Mic_wiring/
Posted on Sep 01, 2009
Why doesn't my radio operate in the "PA" mode?
Some radio's do this (specifically Uniden) for some unknown reason. Ideally you plug a speaker into the PA output and when you switch to PA mode, the CB transceiver part should turn off and only your voice should come out of the PA EXT speaker to make it act like a personal megaphone.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
Uniden 40-Channel CB Radio (PRO505XL) "PA" acts like an extra external speaker!
because when you switch to PA it is because you are on the outside of your vehicle.When another party calls you ,you can hear them and then go to your vehicle flip it to cb and talk to your party.
Galaxy DX-48T why does the meter show receive but unit has no sound ?
is it on CB not pa. Is the squelch all the way to the left and the RF gain all the way to the right, and the AF power wide open.Do you have the volume up.If you answered yes to all these thenyour internal speaker isn't connected or its no good.Is your external speaker plugged into the ext or pa connection?
Jun 01, 2014 | Galaxy Radios DX-48T Base CB Radio
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
Are you following the user manual that came with the radio?
NB-ANL/CB/PA SWITCH: When the switch is in the NB/ANL position, the Noise Blanker (NB) and Automatic Noise Limiter (ANL) circuits are activated.
The Noise Blanker is very effective in eliminating repetitive impulse noise such as ignition interference. In the CB position, the PA function is disabled and the radio will transmit and receive on the speaker that is connected. In the PA position,
the radio acts as public address amplifier. Your voice will come out of the speaker that is plugged into the PA. SP. jack on the rear panel. The radio does not operate when you are in the PA mode.
When you plug a speaker into the ext. jack does it kill the radios internal speaker? It should until you unplug it; if not and you are following the about you may have a wiring issue with the jacks.
Wiring a pa
right next to the external out put of the external speaker is a similer plug .It says PA. set the plug in the outlet and push on it to make sure it goes in and now you have PA.
Aug 03, 2012 | Cobra 19 Ultra II CB Radio
Have a uniden pc 68 elite it seems everything works the whene transmitting the needle moves a. but it has no volume it makes no noise i have tried a different mic i have put a new ext speaker on it and it...
Could be audio chip.
  • Insert external speak jack into pa port.
  • Turn volume down
  • Switch cb/pa switch to pa
  • speak into mic
if you are getting audio from speaker ......chip is fine.
Jan 04, 2011 | Uniden Bearcat Pro PC68Elite 40-Channels...
29 nw LTD no audio on receive out the speaker in the radio or through the ext speaker and on transmit no audio.Radio shows a 4 watt dead key
If you take your external speaker and plug it into your PA jack in the back and key up your mic do you hear anything. If so then its not your IC chip if not its your IC chip and it will need to be replaced.
May 14, 2010 | Cobra 29 LTD CB Radio
148gtl has no recive sound through speaker or ext speaker
Plug your external speaker up in your PA jack key up...do you hear anything...if no you IC Chip is put in your radio.Take to shop. If you do you might have a bad soilder around IC chip on board.
Mar 23, 2010 | Radio Communications
Astatic Vs7 Noise Canceling External Cb Speaker Logo
60 people viewed this question
Top Astatic Radio Communications Experts
AnyMHz.com
AnyMHz.com
Mike Charette
Are you an Astatic Radio Communication Expert? Answer questions, earn points and help others
