Question about Hitachi 50GX49B 50" Rear Projection Television
I just received a Hitachi 50" projection Tv from a friend. He was the original owner and it appears after 8 years the picture quality went bad. After spending some time with the operating manual it appears the the convergance is the problem. Basically you have overlapping colors at the top and bottom in a arc patteren. trying to align this by the manual is not going to work. The stationary Green color + signs are in a arc pattern at the top and bottom. You can move the the Blue and Red color with the remote but you way out of aligmnent. Any known issues or fixes? What is the service mode about on the Digitial Array button? Model is a 50GX49B. Thanks, Joe.
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiI just received a Hitachi 50" projection Tv from a - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
I just received a Hitachi 50" projection Tv from a - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 24, 2009
Sir Myself Raj, My Sony Tv Projection Model is kp
Sir Myself Raj, My Sony Tv Projection Model is kp -es53me1. We are using this tv since 8 years. Now recently we are facing a problem with it. The problem is, The Picture quality is not good. Total screen & pictures are appearing as blur. Would you please give the solution for this?
Oct 10, 2013 | Televison & Video
My 50 inch hitachi hd projection tv picture won't
This T.V. more than likely has a bad lamp. I don't know the model number so look up on ebay for a lamp replacement by model number after you inspect it and find it to look cloudy or exploded.
Jun 20, 2011 | Hitachi Televison & Video
Poor quality color with mostly green tones
Optical Block in your TV is going bad. If you don't have any extended warranty - It is pretty expensive repair and is not worth of fixing it in most cases.
Mar 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Projection tv no picture has sound no picture
Try resoldering the vertical output IC. The crts may be blanking due to vertical deflection dropping out.
Apr 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
Tv picture quality
You have a defective light engine. We just went through this and we have the same TV that you have. Hitachi knows about the problem but will play dumb when you first call. If you deal directly with their Customer Relations Department 800-654-7013, it will make a lot of difference than regular customer service.
Here's how they handled our situation. We called Hitachi after lots of research online and they gave us the names of some certified dealers in our area. The tech came out and in less than 1 minute said the TV had a defective light engine. We called Hitachi back and low and behold, they are aware of the problem...imagine that. Hitachi called the dealer directly and once the dealer confirmed the problem, they agreed to send a brand new light engine out to the dealer and the tech came out and replaced it. Here's the kicker...Hitachi will pay the for the part ($1500) but they ask you to pay for the install. Our install was $400. This was worth it to us being that we spent $3600 on this set 3 years ago. Once the light engine was replaced, the TV looked BRAND NEW! Please deal with their customer relations department at the number I lised above. If you deal with customer service, they will have you chasing your tail...so to speak! Good Luck! If you're willing to cover the install, the rest should go pretty smoothly..at least it did for us:)
Nov 19, 2007 | Hitachi 60V500 60" Rear Projection...
Surround Sound Installation
The Hitachi 50UX57B is a 50 inch standard projection TV with a standard screen. It is not HD ready. If you need it, I think I can download the owner's manual (in PDF format) from Hitachi and foward it to you.
Aug 03, 2007 | Hitachi 50UX57B 50" Rear Projection...
Rear projection tv hitachi
when it snaps its most likely a tube that shorted or flyback that went bad.
May 31, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 50GX49B 50" Rear Projection Television Logo
290 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
