Question about Tools & Hardware - Others
Staple Gun isn't working-staples not coming out. I have a Rapid Proline R14 Ergonomic staple gun which is not firing staples. Making all the right noises, but no staples coming out. Is the metal rod which is surrounded by a spring supposed to move as I close the staple slide after refilling?
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Posted on Apr 21, 2011
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
danny_murray
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
joboo1
  • 257 Answers
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 27, 2009
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
How to load staples?
    • 1 Push in the push rod plate on the back of the Arrow T50P and press down to unclip the push rod from the gun. Pull the push rod out of the staple channel and away from the staple gun.
    • 2 Insert a strip of staples into the channel with the tips of the staples pointing toward the bottom of the staple gun.
    • 3 Place the end of the push rod into the staple channel of the gun. The end of the push rod has a small, solid piece of metal that fits into the staple channel.
    • 4 Press the rod all the way into the staple gun until the rod plate engages in the notch at the rear of the gun.
Jun 26, 2011 | Arrow T50P ARROW STAPLE GUN
My stanley tre500 shoots like a semi automatic weapon. Is it adjustable? Thanks Nancy
Hi Nancy,
Do you mean it rapid fires, or do you mean fires the staples to deep?
If it fires too deep, the adjustment for that is on the back of the gun. The + and - give more/less depth. Adjust it towards the - direction to get the brad/staple to no penetrate as far.
Thanks,
Handie Andie
Jun 16, 2011 | Electric Stanley Tre500 Staple Gun /...
No instructions came with the stapler and the . I can't get it open to install staples! I need this now. You start a project and can't get what you need! I was expecting more from a product...
Open the PowerShot staple gun staple chamber. This is found on the front of the staple gun. There is a small metal area on the bottom. Pull down on this and the interior of the staple chamber is revealed.
  • Remove any existing staples that may be in the chamber. These can be pried out with your fingernail, or you can turn the staple gun upside down and gently shake the staples loose.
  • Slide a new row of approved staples into the PowerShot staple gun. These need to be slid in from the base of the staple gun (where you pulled the cover of the chamber off).
  • Close the cover to the PowerShot staple gun's staple chamber and you are ready to use your staple gun on the next household project.
  • May 07, 2011 | Powershot Tool Company Tools & Hardware -...
    My gun will not shoot staples after loaded I thin there is a part missing
    Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
    Hope it helps!
    May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
    Reloading ace 22084 staple gun
    Hello there:
    when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
    best regards michael
    Oct 03, 2009 | Ace Hardware Ace Staple Gun
    Piece of staple stuck in the trigger section of arrow t-50p
    First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
    Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
    Bostich nail gun plumger not retracting
    spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
    Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
    Staple gun support
    Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
    Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
    Aug 27, 2008 | Arrow T59 Wire & cable staple gun
    Tools & Hardware - Others Logo
    108 people viewed this question
    Top Tools & Hardware - Others Experts
    J.D. Browning
    J.D. Browning
    Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
