Question about Craftsman GT 5000 26 HP54" Garden Tractor ()
Tractor smokes runs hot - Craftsman GT 5000 26 HP54" Garden Tractor ()
Smoking after riding for about 10 minutes.
Are you sure your oil level was not over filled..if there is smoke there is oil being used..have your compression checked..sounds like your rings and cylinder walls may be worn and when hot oil will be forced past the rings and remain on the walls and into the firing chamber and ignited and partially burned...I.E.the smoke out the exhaust...it not over filled and compression is ok..have the crankcase venilation checked by a service garage...good luck..
Aug 30, 2015 | Garden
Out of the blue the 2 cylinder water cooled Honda started blowing White Smoke
Does this machine use regular transmission fluid? If it does, check to see if there is a small line (normally rubber) that runs from the carb to a transmission diaphragm. If there is, disconnect the line and tap it. If trans fluid is noticeable in the line, you must replace the as it contains a rubber diaphragm inside which goes bad eventually leading to trans fluid being sucked into the carb and though the exhaust which creates large amounts of white smoke.
Jun 06, 2013 | Garden
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
TO-30 quit running, puff of smoke from electrical? Won't turn over
It is possible to have the solenoid go bad but not while the tractor is running as it is only used to engage the starter. It sounds like the wires to the starter is shorted out. I would run a hot wire to the solenoid from the battery to the solenoid and see if it will start. Just be sure everything is grounded. If the ground cable on the battery is ok you should not have a problem with running a hot wire to the solenoid. Just touch the hot wire to the starter and then release it when the starter engages. Hope this helps.
Apr 16, 2017 | RTO Massey-Ferguson Tractor TE20, TO20,...
Replced belt on yardmachine rider but rider smokes
Look for oil dripping from engine onto exhaust and/or onto drive belt.
Hot oil smokes..
Jun 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My lawn tractor is smoking and then the engine dies. what should I look at?
1st..make sure it isn't over full of oil that would make it smoke then check the compression you may have bad rings that makes it smoke both of those will also make the engine quit running as well...good luck
Apr 12, 2010 | Craftsman 16" High Garden Tractor Snow and...
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Sep 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Using oil...no leakage...no smoking
by recently, do you mean, since it got hot outside? if you're using a multi-vis oil, it gets too thin in hot weather and will "vaporize" and burn, not enough to cause smoking. use a good 30 weight oil. other than that, can't think of anything else that would cause it with no leaking or smoking
Aug 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman GT 5000 26 HP54" Garden Tractor () Logo
13 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
