No connection to internet
Rj45 colour codes for cat5e cables
  • 3 Answers
There are 2 common colour codes for Cat5e. In Australia the most common is T65A Colour code for this is below
Pin 1 is Green T3
Pin 2 is Green R3
Pin 3 is Orange T2
Pin 4 is Blue R1
Pin 5 is Blue T1
Pin 6 is Orange R2
Pin 7 is Brown T4
Pin 8 is Brown R4
A very good link for this is http://www.grech.net.au/networking/utp/index.html
Hope this helps,
Cheers,
Jason
Posted on Apr 24, 2009
What cord connects an xps 600 to the internet
Via ethernet cable called CAT5e, using RJ45 connector.
It goes into your LAN/Ethernet port on the rear of the machine.
Take care!
damnor01
Sep 15, 2012 | Dell XPS 600 PC Desktop
How to connect RJ45 cat5 cable in wallmount I/O box
how i can punch cat 5 cable in cat 5 io box
Mar 01, 2011 | Leviton (102-5G108-RW5)
I want to connect a CAT5e Ethernet cable (with or without a RJ45 connector) from a DSL router to an older computer that only has a RJ11 input. This will be used for DSL internet service only -- no...
The only "outputs" from a DSL-router are:
* RJ-11 telephone-jack, only if the router also supports voice-over-IP,
* RJ-45 Ethernet port (always present)
You need to purchase an internal network-card, to create an RJ-45 port on the computer, and then use the CAT-5e cable to make the connection.
Feb 20, 2011 | Computers & Internet
I only want to know the meaning of the different colours of cables that are used in crossover cables?
the standard colours for CAT5(e) or CAT6 ethernet cable are:
green, green stripe
blue, blue stripe
orange, orang stripe
brown, brown stripe
the typical setup for an ethernet connection in an RJ45 (the crystal end with the connection tab towards you) is
2 green
3 orange stripe
4 blue
5 blue stripe
6 orange
7 brown stripe
8 brown
Wires 1 & 2 are used to transmit data from the PC to the router/modem (TX) and wires 3 & 6 are used to recieve information from the modem/router (RX). in this fasion, information flows along one pair or another and is expected to arrive at that pinout. the router/hub/modem takes care of the transition to the next cable or out to the internet.
In a crossover cable ONE end is configured as above, but the colours for wires 1, 2, 3, and 6 are exchanged so that when no hardware is between the two PCs/components the signal is transmited at wire 1 & 2 and recieved on pins 3 & 6 on the other system/component. the other colours are placed for backward compatibilitiy and other applications, such as power over ethernet.
following the standard above allows anybody familiar with RJ45 connections repair a connection with a standard colour code and pattern without having to see the other end. If you know you need to replace one end of a patch cable, you use the standard termination.
Oct 12, 2010 | Computers & Internet
Hub to hub how to connect cat5 cable
make a cross cable find the colour code on google
how to make cross cable
Apr 24, 2010 | Cat5e Cat 5E Modular Plugs - For Round...
Require assistance in connecting cable to a single CAT5e configured wallplate
Well, what can I say? you only need a cat5 ethernet cable with rj45 plugs and plug one side in your computer and the other in the wallplate, beside that with this information I can not say anything else.
good luck
Apr 10, 2009 | Computers & Internet
Network cable stopped being recognized
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
I have a cat5e network cable i am hooking to rj45 flush mounted wall jack the wire color is not the same?
Either your wallmount is not correctly crimmped according to the standards or your cable is not correctly crimmped according to the standards. So its better you crimp the cable and fix the R.J 45 connector in the sequence given herewith.colour coding of the cable:-
1-oranage white
2-orange
3-White green
4-Blue
5- White blue
6-Green
7-White brown
8-Brown
The same Sequence should be at the wallmount and at the R.J 45 connector.
Apr 26, 2008 | Computers & Internet
Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Nov 04, 2007 | Cat5e Cat 5E Modular Plugs - For Round...
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
