Question about Ingersoll Rand 14" Heavy Duty Air Angle Die Grinder
My ingersoll rand die grinder won't spin. - Ingersoll Rand 14" Heavy Duty Air Angle Die Grinder
5 Suggested Answers
SOURCE: ingersoll 261 problem
that tool is under warrenty whoever u bought it from should have it fixed. did u try to adjust the air flow on your forard and reverse by turning the nob right or left has numbers on it hold the trigger turn the nob i see what it does i rebuilt many a 261
Posted on Feb 21, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
  • 3192 Answers
SOURCE: how to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Posted on Aug 03, 2016
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Air compressor starts and builds air then idles and when it goes to rebuild air it dies
if your saying it wont recover from idle down mode back to full speed , this might be the IR fuel pump/regulator problem (a pressure gauge will need to be added to verify this ) , if so save your money go with an aftermarket pump it'll last longer
Mar 25, 2014 | Ingersoll Rand Air Tools & Compressors
Air disc grinder will stop run after wheel grind touch the surface metal
You don't have enough air pressure. Let the compressor build up more air pressure, and check to see if you have an inline pressure regulator (like you might have for a paint shop). If you can, bypass the pressure regulator to use full compressor pressure.
Feb 03, 2014 | Ingersoll Rand - Rand 308 Heavy Duty Air...
Problem with Ingersoll Rand - Rand 1/2" Impact Wrench, Quiet Tool with Extended Anvil wont shutoffwont shutoff
The IR 2135-k303 air inlet repair kit along with a IR 2131-322 inlet removal tool should fix your problem.
Jun 02, 2012 | Ingersoll Rand - Rand 1/2" Impact Wrench,...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
The grinder does not turn.
Possibly has a blown seal from operating at too high a PSI letting the air leak out and not directing it towards where it needs to be to turn the tool. It will need to be taken apart and inspected to find the problem. Sorry I couldn't be more of a help.
Nov 01, 2009 | Ingersoll Rand Air Die Grinder Angle Std...
Ingersoll Rand 14" Heavy Duty Air Angle Die Grinder Logo
Top Ingersoll Rand Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ingersoll Rand Saw Expert? Answer questions, earn points and help others
