Question about Frigidaire FRS23R4A Side by Side Refrigerator
Not Cooling or freezing.
Hello We have the and problem that we are having is that it will not stay cool or freeze like it is suppose to. Its in excellent cosmetic condition and we dont want to part with it.
You need to clean the evaporator coil under bottom off refrigerator. and check in the back of refrigerato to see if fan is runing. I not you need a replace it sam
Posted on Sep 25, 2007
  • Anonymous Sep 25, 2007
    Frigidaire freezer have a lot off ice build up inside. What cause it.?
    It is a timer ?
    It is a control temperture ?
    It is a heat exchang not work ?
SOURCE:
Cools but does not freeze
turn up the cooling knob to a lower temp and make sure doors are well closed
May 19, 2014 | Refrigerators
My frost free freezer stops freezing although it stays cold and then I have to switch it off for more than a day before it starts freezing again
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool Refrigerators
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
Overheats and freezes
Please try to cool it down then install a cooling system of a fan that can help your device stay in its cooling temperature. Note that all device has its own cooling temperature so it is recommended that you also know the standard temperature particularly the limits temperature of your device.
Thanks
Aug 07, 2009 | Sony PS3 BAJA EDGE OF CONTROL IN SEALED...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
What is a freeze plug
Your engine is water cooled and therefore has water travelling around the engine block.
A freeze plug is an expansion plug located in the side of an engine block that is supposed to protect the block against freezing conditions. Water expands when it turns to ice, and if the coolant does not have enough antifreeze protection it can freeze and crack the engine block. The freeze plugs (there are usually several of them) are supposed to pop out under such conditions to relieve the pressure on the block.
Most of the plugs to be found on an engine are actually to plug the holes where sand cores have been held. The sand cores are used in the casting process to form internal cavities in the engine block or cylinder head, for cooling water for example, and so should really be referred to as core plugs.
Freeze plugs can often be a source of troublesome leaks as a result of internal cooling system corrosion. Ease of replacement depends on accessibility. In many cases the plug area will be difficult to reach and using a mallet to perform maintenance or replacement will be nearly impossible without special facilities. Expanding rubber plugs are available as replacements when access is a problem.
Hope that helps...
Aug 21, 2008 | 1992 Nissan 240SX Fastback
Frigidaire FRS23R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
