Question about Mopar Performance Mopar Uconnect Phone Bluetooth Wireless Hands-free Kit 82212499
Uconnect Bluetooth cannot call out either by dialing or hands free. Calls coming in are fine.
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
Jan 13, 2018 | Cars & Trucks
Can't dial out
this seem issue with the firmware. get the firmware reinstalled then try.
Sep 22, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
How to connect my phone to my car system?
Not all Chrysler products have uconnect; it may show the button on the radio, but if the uconnect system isn't installed you get the error you're getting; My Dodge Nitro is the same. You can buy the uconnect from the dealer or off of eBay (they run about $300, plus it has to be installed) Details about Dodge Chrysler Jeep Ram Hands Free Uconnect Kit OEM MOPAR
May 24, 2015 | 2010 Chrysler 300 Touring
Uconnect terminates when "Bluetooth streaming audio" command is given in my 2010 dodge grand caravan.
Select Bluetooth on both devices. Seams the uconnect is being canceled out by your Bluetooth. Or use uconnect as opposed to Bluetooth. Maybe seek further advice, I am not the expert on this one :<
Sep 25, 2014 | 2010 Dodge Grand Caravan
Hi there!
Depending on your car's navigation system, this may or may not be available.
On some newer models (such as the Chrysler 200/300) that have uConnect, the bluetooth sync feature supports both phone calls and text messages. To activate, simply sync your phone to your navigation system using Bluetooth. If that does not work, you may need to consult your navigation system's manual or contact the manufacturer for additional information on supported devices. In some cases, an extra app is required to do certain things.
Hope this helps!
Jul 31, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
I want to make and receive handsfree calls using an LG HBM-730 bluetooth device and an LG CF360 phone. I have the bluetooth and the phone connected and can receive calls and make calls. The kicker is...
Hello.
From LG Documentation:
To make a handsfree call from the bluetooth device (Voice dialing)
- Briefly press the PWR/END button to activate “Voice Command”.
You will get the best results if you first record the voice dialing tag through
your Headset.
Hope this helps
Mar 09, 2010 | Cell Phones
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
Dec 29, 2009 | 2005 Chrysler Pacifica
2008 dodge ram REC radio
i only recived the channels
Mar 19, 2009 | Alpine Car Audio & Video
Bluetooth Stereo headphones
according to the specs ive read these are the bluetooth profiles supported by your phone :
Bluetooth® Supported Profiles: dial-up networking, headset, hands-free, file transfer, imaging, printing, JSR-82
copied directly from motorola website........so in other words your phone does not support the bluetooth stereo profile.....so the headset may function as an earpiece but music play wont be possible
Dec 13, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Mopar Performance Mopar Uconnect Phone Bluetooth Wireless Hands-free Kit 82212499 Logo
15 people viewed this question
Top Mopar Performance Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Mopar Performance Cell Phone Expert? Answer questions, earn points and help others
