Question about Ruud UBHC Air Conditioner
Uaka 030jas contactor - Ruud UBHC Air Conditioner
3 Suggested Answers
SOURCE: I am trying to find a parts list for a RUUD
RUUD will only sell there factory parts to certified contractors. My advice to you is to find a local HVAC parts distibutor that will sell you generaric parts which will work just as good as the factory parts.
Posted on Oct 22, 2010
bobicehouse
  • 1524 Answers
SOURCE: wiring diagram for ruud UAKA 030 JAZ contactor
E mail me @ Bobicehouse58@yahoo.com I will e mail it back
Posted on May 01, 2011
Wiring diagram for ruud UAKA 030 JAZ contactor
May 01, 2011 | Ruud UAKA030 Air Conditioner
Model UAKA 030JAZ was working fine. Now, the compressor fan does not come on and neither does the compressor. I don't know how the contactor works but it is not engaging (the spring loaded contacts are...
Hello
You need to complete the 24 volt circut from the themostat to the transformer to get the contactor to pull in.
Check for voltage at the transformer,should be 120 v in 24 volts out.Also there may be a small reset button on the transformer.
Apr 18, 2011 | Ruud UAKA030 Air Conditioner
RUUD uaka-036jaz not cooling, outside fan does not turn on but air handler (in attic) runs and circulates hot air - how to fix and/or reset?
Check your disconnect or breaker that is located close to the outside unit. Next you need to check the contactor in the outside unit. Set the thermostat to make the air come on then check the contactor. It should be pulled in closing the contacts. If it isn't the problem could be the contactor or thermostat. Next check the voltage on the load side with it pulled in. If that's good then check the capacitor. If it looks swollen, it's bad. You can also use a multimeter with the capacitor check function to do this. Let me know what you find.
Sep 27, 2010 | Ruud UBHC Air Conditioner
I am trying to find a parts list for a RUUD UAKA-030JAZ air conditioning unit (specifically the compressor/condensor contactor).
Jun 23, 2010 | Ruud UAKA030 Air Conditioner
I am trying to get an electrical schematic of my RUUD 3.5 Ton condensing unit UAKA-042JAZ. The one that is attached to the inside of the unit's cover is not readable. Where can I get another drawing to...
thers 2 sides of power in the entire unit besides the 24 volt control wires! what are you trying to make run? theres a fan and compressor, both operated off the same contactor!!
Aug 22, 2009 | Heating & Cooling
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
Unit not turning on rudd model UAKA 024JAZ
Check float switch at Air Handler inside. Check breaker to outside unit. May have red button on outside unit by copper lines may be tripped. Have someone turn on unit while you stand by it. Can you here the contactor pull in. If so you have a high voltage problem. Call service tech adn ask for free estimate. That way you know what is going to cost you. Rus
Jun 27, 2009 | Ruud UBHC Air Conditioner
I have a Rudd uaka-037JAZ. I was cutting my lawn and accidentally cut the small wires going to the unit. I reconnected the wires but the unit will not come on.
You possibly shorted out the indoor transformer. The primary side of the transformer will open/burn up when low voltage wiring is shorted. But if indoor unit comes on i.e fan motor works and you cant hear contactor come on on the outside unit you may still have and open circuit on those wires you broke. If you hear the contactor hum or come on you may have a problem with incoming power to the outdoor unit or a pitted contactor. Try those things first.
Jun 06, 2009 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
22 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
