HPw2207h Monitor put into sleep mode and will not wake up. Have tried disconnecting everything, switching off and reconnecting but no luck. Screen starts off with the usual No Signal screen but then says Monitor going to Sleep. When I press Menu on front of Monitor it just brings up the Monitor going to Sleep message and then goes blank.
  • 1 more comment
  • mjfamhist Apr 24, 2009
    Have tried all the basics but still the monitor is saying Monitor going to Sleep. My computer is HP Pavilion m9170a PC (GX726AA)and it seems to be OK - just not waking up the monitor.
    Thanks for that. Checked all plugs but still no luck. Have spoken to friend re problem and he says it seems as if it is the computer itself. When it is switched on the green light flashes for a couple of seconds and then goes off and the screen just shows the No signal screen and then the Monitor going to Sleep message. Computer was working fine last night until it was put to sleep via the screen. Any thoughts on this would be appreciated otherwise looks like a trip to the experts via my warranty.
  • mjfamhist Apr 27, 2009
    Thank you for all your help. Probably is just what you say but have taken the tower in under my warranty. Decided that would be the quickest solution but appreciated your help.
    President:
  • 1,223 Answers
It seems like u are having problems in ur PC have u tried this monitor on notebook vga out in case to confirm or any other device that have VGA out
Posted on Apr 24, 2009
  • Shoaib Rais
    Shoaib Rais Apr 24, 2009
    i can solve this problem it is in the pc hardware simple as re seating RAM and VGA card if any pls reply it will be solved i am sure
  • 600 Answers
Sounds like the monitor is not getting an input ( it will read "going into sleep mode" or "no signal input" by default if its not getting input... check the vga/monitor cable to make sure it has not come loose on either end
  • 854 Answers
You can try this..Click here.
Posted on Apr 23, 2009
Sleep mode
well to wake it up you usually have to press a key(any key) to wake it up, try this video on removing the ram and see if it helps:
http://www.youtube.com/watch?v=jBIN6tNyfMY
Hope it does : )
Apr 15, 2012 | Apevia Computers & Internet
Hi to all, can you help me guys, i am having a problem with my Lcd monitor AOCTFT1560ps, my screen turns black after a few seconds and my OSD was locked..... HELP ME GUYS!! thanks
This link may help. You can try to do something if it is connected to a computer. If not, you can disconnect the video cable from both end and wait for 5 minutes and reconnect it. After your monitor wake up, use your OSD to disable sleeping mode, hiberation mode or turn off monitor mode within power options.
Nov 03, 2010 | Computers & Internet
Monitor is changing colors and won't wake up
This problem should not be only with your monitor, but also with your video card. You might have left one image sitting for long hours. There is no specific solution, but for Lcd users, you can try this. Leave the monitor off for few hours without any connection, maybe power chord or vga/dvi/hdmi cable. If this doesn't fix then the problem must be from your video card. You can try the monitor on another system to make sure, which one is the culprit. Your last choice is to reset the bios, to do this, remove the bios battery and leave it for few minutes outside (2 mins will do) and put it back. Reboot your system, this will fix your problem. Good luck. Thanks for using FixYa.
May 31, 2010 | ViewSonic VA721 17" LCD Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Screen does wake with computer
go 2 control panel and select power management and configre ur monitor time when it go to sleep mode. thanks
Jul 29, 2009 | Computers & Internet
Gateway monitor fpd2185w goes to sleep and then shuts off
I suggest to mess around with the monitor buttons and see if you can disable it from sleeping from there. If not then try enabling it to sleep on your computer settings. A good restart after any changes is always helpful.
Jul 07, 2009 | Gateway FPD2185W 21 in. LCD Television
Monitor will not turn on
My LG L19534H (analog) flat panel monitor began doing this too after two years of good performance in a Windows XP Pro environment. Here is my crude "fix": right-click desktop, hit Properties, select Screen Saver tab, hit Power button, and choose "Never" from the drop down lists for Monitor and System Standby. Hit OK to save changes. Yes...you're right...what if you need standby, etc. Don't know if it's video card starting to fail or not. Time will tell. Hope this helps for now.
Apr 04, 2009 | Dell E228WFP LCD Monitor
I have a Dell Inspiron 530
I have a Dell Inspiron 530S, and it exhibited the same symptoms as rguggemos's & Wilburollie's.
I can put it to sleep, but when I try to wake it, it won't. The screen will stay black. I can hear the drives spin up, and the fans go on FULL blast, and the blue power LED stays flashing, but the computer will stay like that - no picture or anything. Then I'd have to press & hold the power button to force it off, then power back on. Not ideal.
The solution that worked for me?! On boot, at the "DELL" logo, hit F2 to enter the BIOS setup, go to Power Management, and change the standby mode from S3 to S1. The difference? S3 is a "deeper" sleep, w/ more components powered off, which is better, energy-wise, but it is more difficult to wake from. S1 is a "light" sleep. Give it a shot! Maybe it'll work!
- Mike
Stolen from another forum:
S0 (Working) is lit. The CPU functions in entirety; the conservation of power is on a basis of by-device.
S1 (Sleep). The CPU is stopped; The RAM is regenerated; the system functions in reduced power.
S2 (Sleep 2) The CPU does not have any power; The RAM is regenerated; the system is in lower mode of the S1.
S3 (Standby) The CPU does not have any power; The RAM regenerates at minimum; the power supply unit is in mode of reduced power. This mode is also called “Save to RAM”.
S4 (Hibernate). All is powered off, but the memory was saved like temporary file on the hard drive. This mode is called “Save to disk”.
S5 (Off) Everything is shutdown. Means you need a full reboot.
Dec 11, 2008 | HP Media Center m7060n PC Desktop
I have a kyocera kc 100 viewer and it wont wake up the pc monitor can ya help?
I'm confused as to how you're connecting this with s-video. Are you using an RGB / s-video adapter?
What is the exact monitor brand / model?
Jan 12, 2008 | Sharp 17" Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Open Questions:
Plans For Online Storage And Online Backup - Dataalign Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
