Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Will not come on
I believe we need a PCB PWR DEF CKT BD. BUT I CAN'T GET A GOOD PART # FOR IT. CAN YOU HELP?
  • 3 Answers
What are the exact symptoms when you turn it on? don't leave anything out. does it make any specific noise that you recall? does it seem to cycle on and off without fully coming on while making a squealing noise from the back of the set only stopping when the set is unplugged? has any service at all been performed to this set prior to this problem?
Posted on Oct 15, 2007
How to solve error 100-0001
Code E100-0001 Description The BD signal is not detected 10 times or more within 10 msec in 5 msec after the generation of the laser drive signal Causes The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The laser scanner unit is faulty. The DC controller PCB is faulty. Remedy 1. BD PCB Try replacing the BD PCB. Is the problem corrected? YES: End. 2. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Dec 05, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
CODE ERROR 100 SHOVING IN I R 3300 CANNON XEROX
You may need to replace the laser, it may have failed, this is from the service manual
E100
0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec
after the generation of the laser drive signal.
0002 While the laser is ON, the BD signal cycle is outside a specific range 20
times or more continuously.
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific
range 20 times or more.
Main cause The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The
Action
1. BD PCB
YES: End.
YES: End.
anual.
Aug 30, 2014 | Canon IR 3300 Digital Copier
A350d not power on
charger, battery, pwr socket, pwr button/ckt
Dec 10, 2013 | Toshiba Satellite A3 A355D-S6922 Notebook
Pwr-0501ssb-dmp-pcb no sound
The best you can try the same at Mumbai where there are many shops in the Lamington road but I fear that the PCB will be available.
Try for a good service shop to do a final check for a component level service.
Oct 09, 2012 | Audio Players & Recorders
What does the code po753 refer to
Symptom:
P-0753 TRANS 3-4 SHIFT SOLENOID/TRANS RELAY CIRCUITS
When Monitored and Set Condition:
When Monitored: Continuously with the key on.
Set Condition: This code is set if the voltage detected on the 3-4 Shift Solenoid Control
Circuit at the PCM is different than the expected voltage.
POSSIBLE CAUSES
FUSED B(+) FEED TO THE TRANS CONTROL RELAY OPEN
3-4 SOLENOID WIRING HARNESS INTERMITTENT DEF
3-4 SOLENOID WIRING HARNESS OBSERVABLY DEF
SHIFT SOLENOID CONTROL CIRCUIT OPEN
SHIFT SOLENOID CONTROL CIRCUIT SHORT TO GROUND
SOLENOID AND HARNESS DEF (SOLENOID CONTROL CKT)
TRANSMISSION RELAY OUTPUT CIRCUIT OPEN
TRANSMISSION RELAY OUTPUT CIRCUIT SHORTED TO GND
PCM DEF (3-4 SOLENOID/TRANSMISSION)
PCM DEF (TRANS 3-4 SOL/TRANS RLY CKT)
POWERTRAIN CONTROL MODULE DEFECTIVE
SOLENOID AND HARNESS DEF (SOLENOID PACK CONN)
TEST COMPLETE
TRANSMISSION CONTROL RELAY DEFECTIVE
Feb 03, 2012 | 1999 Dodge Dakota
Error 0100
E100 BD error has occurred. • The laser unit has a fault. • The BD PCB has a fault. • The BD PCB has a fault. • The laser driver PCB has a fault. but it could also be the CCD unit
Mar 18, 2010 | Canon imageRUNNER 400S Copier
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Canon IR2020 photocopier system error E100 how can I fix this problem
BD detection PCB failure
The BD detection PCB is faulty.
- Check the connector of the BD detection PCB.
- Replace the laser scanner unit.
- Replace the DC controller PCB
Jun 30, 2008 | Canon imageCLASS D320 Digital Copier
TV problem
  • it is 100% sure the problem is in red video output ckt only.
if you familiar with electronics please check the following.or call tech.
  • crt base for loose.
  • connector to crt base loose.
  • supply to red video output transistor ckt.& red video output transsistor.
  • components related to red video ckt.
  • red video signal coming to red video output frem processor.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Pioneer pro-119
JDM-RECHECK ALL CONNECTIONS ON POWER/DEF PCB AND ALSO TAP AROUND FLYBACK TO TEST FOR POOR SOLDER JOINTS.CENTER LINES USUALLY INDICATE IMPROPER HORIZONTAL CIRCUIT OPERATION.IF ALL ELSE FAILS RE-REPLACE SAME BD. JOE TV
Aug 21, 2007 | Pioneer PRO-200 60" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
