Question about Saniflo Home
I need a spare part for a Saniflo Sanivite 3 - part 21b the rubber non return valve flap Can anyone help me find someone who sells these thanks
2 Suggested Answers
  • 33 Answers
SOURCE: where do i buy rubber non return valve that fits on
you may not get a rubber one, but you can certainly get 32mm and 40mm non return valves from most plumbing suppliers
Posted on May 10, 2010
Non return valve saniplus toilet
The valve could be defective or could have become clogged.
Dec 06, 2013 | Saniflo & Saniplus& Macerator Pump
Saniflow problem
My Sanivite has packed up again (humming no pumping) for the third time, (7years old!) always the capacitor, don't buy from Sanivite get off ebay half the price.
May 29, 2012 | Saniflo & Saniplus& Macerator Pump
Sanivite 3 makes humming noise and no longer pumps water out
Jonathan: You need to remove the pump from the shell and make sure the grinding impeller is not cloged up with hair or other junk. Also, is you drain line out of the unit completly clear?
Dec 12, 2011 | Saniflo & Saniplus& Macerator Pump
Motor will not shut off unless disconnected from the electrical outlet. Unit is connected to toilet - tub & sink. Unit model is: Sanivite EN 12050-2 FF0V30 120v 60Hz 5,7A 4/10 HP age 4 yrs.
The Sanivite is a gray water pump, does not have a connection for a toilet. It has a pressure chamber inside the pump casing and a float switch at the bottom of pressure chamber. You will find a black rubber membrane which water pressure pushes up on the membrane and turns the unit on and off. It could be that something is stuck at the bottom of the membrane keeping it in the on position the whole time or the membrane might be warped. Also the micro switch may be stuck on the on position. Pry open the lid with a flat head screwdriver and inspect the pressure chamber.
Sep 04, 2010 | Saniflo & Saniplus& Macerator Pump
Motor runs contiuously. Non return valve pipe and circuit board have been replaced but problem remains..please advise me..
Which pump model is this? Could be that the pressure chamber may be stuck on the on position. There is a rubber membrane at the bottom of the pressure chamber which turns the unit on and off. The membrane may be warped, a piece of solid may be stuck at the bottom or the micro switch can be stuck on the on position.
Jun 19, 2010 | Saniflo & Saniplus& Macerator Pump
Sanigrind pump don"t always start on all fushes
certainly indicates that the unit is not holding water (hence not starting on every flush). as you are seeing water in the shower - this is obviously where it is going. It may be that the internal flap (non return valve) is stuck open or damaged. If damaged you can put a new non return valve in your 40mm pipe run where the shower pipe enters the saniflo - about a tenner from most suppliers.
Feb 13, 2010 | Saniflo & Saniplus& Macerator Pump
Where do i buy rubber non return valve that fits on the wastepipe that goes on a saniflo
Nov 19, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Home Logo
600 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
