Question about Breville BCG450XL Manual Burr Grinder
Grinder stuck I took the grinder and bean hopper out to clean them and now I can't get the hopper to turn. I put the grinder inside and lined it up with the slots, put the hopper on top with the "aligned" signs lined up and it won't rotate.... Help!
SOURCE: I cleaned my Breville grinder
This might be it. On the bean container there is a white dart and the word 'align'. The same dart and word appear on the top of the grinder. Align the two darts and the bean container should drop right in.
Posted on Dec 19, 2008
SOURCE: I cleaned my Breville grinder and tried to put it
This is happening to me too. Did anyone solve this issue? How did yours get fixed? Thanks!
Posted on Apr 08, 2010
SOURCE: beans wont grind through.
Return this machine to your retailer for another. Breville has a replacement warranty. Thank goodness because we are onto our 4th machine in 7 months. Many problems. Firstly it leaked water from the front of the machine, second machine grinder wasn't adjustable so it grinded too fine for pump, same with 3rd and 4th machine. We are opting for a refund tomorrow! Good luck.
Posted on Aug 01, 2010
ginko
  • 19396 Answers
SOURCE: I ground some nuts for
Hi.
The problem is not the motor.Coffee grinders must only be used with coffee. Even the beans used must be of quality suitable for the grinder. Too oily blends will result in a jammed grinder, as happened after grinding the nuts.
The repair is done disassembling the grinder, cleaning mechanics and reassembling. Unless you have disassembled a similar appliance before (eg. a blender gear box), there is a good chance that the attempt of fixing the grinder will result in more problems.
Rather than disassembling, a good alternative for the user is calling the Breville number listed on the grinder manual, and discussing repair with the manufacturer.
Regards.
Ginko.
Posted on Feb 01, 2011
  • 5 Answers
SOURCE: My grinder does not grind anymore. The machine
im only guessing here but id assume that the space between the burrs is likely controlled with a spring or something which has probably broken leaving the burrs as far apart as possible, if you gut the machine you may just be able to fix it with no parts if its simply a spring thats come off, the only other possibility i can think of is that your burrs or whatever they connect to are broken somehow, but all these are only guesses as im not familiar with your machine, my motto is if its broken you may as well pull its guts out to see if you can fix it, youve nothing to lose and youd be surprised how often it works
Posted on May 15, 2011
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
I have cleaned my machine and put the grinder back inside its housing but it says the grinder is blocked and won't operate. I cannot understand where it can be blocked.
You removed the grinder? Or you removed the outer burr from the grinder? It can be tricky to get back in place with the correct lineup. If you don't do it just right, it won't sit down in place like it is supposed to. Here are the full instructions, you may just need the last little bit about lining the burr up on reassembly.
From wholelattelove website:
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
How do i reset my gaggia titanium, the gears are in the wrong position
Are you talking about the coffee brewing system? Or the coffee grinding system? You said "gears" so it sounds like you took the coffee bean hopper out and the adjustment knobs come out with it. So if you are trying to line those gear teeth back up correctly, Here is the complete instructions for cleaning the grinder (from wholelattelove.com). You only need the last few steps for lining up the gears.
Reinstalling
Sep 24, 2010 | Gaggia Titanium Espresso Machine
Machine says beans are empty and will not brew.
Try adjusting the grinder coarser when it is running. Either the grind is too fine or the grinds chamber is blocked, remove the brew unit and check the gate to the grinder on the inside right.
Jul 30, 2010 | Saeco Magic De Luxe Espresso Machine
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Embarassing but...
No, wait, I found it. If it's round and is (or used to be) white, it fits on the bottom of the clear plastic hopper. Replace it and you should be in good shape again.
Jan 02, 2009 | Solis Maestro Electric Burr Grinder
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Breville BCG450XL Manual Burr Grinder Logo
90 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
