Question about SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2GB to my computer it doesnt show in My Computer section so that i can down load music into it
  • 3 more comments
  • Livestick May 02, 2009
    I have the same problem. Tried rpmcclenny's solution and now it won't turn on at all.
  • amw_500 May 03, 2009
    trying ta download music dosent show up on my comp (windows xp service pack 2) how do i get it to recognize device and show up
  • mimi3g4s May 04, 2009
    i have tried everything but nothing is working. i have vista and the very first time i connected my clip, it worked. it didn't work the second or third time, but it worked the fourth. after that, it's not working. my sansa clip says its charging, but it doesn't show up under my computer or windows media player. i tried holding the power button up for 10 seconds until it restarted and shut itself down, but it didn't work. i have even tried the 'forced msc' method, but it hasn't worked. i'm pretty sure that my sansa clip is stuck in mtp mode. even when i change the setting to msc mode it is still recognized by my device manager as an "mtp device." is there any way to fix this?
  • ibbeanie2 May 08, 2009
    mine froze. then i got it to turn off. but now it won't show up in my computer to put new music on, and it won't charge but the clip shows "connected"
  • MUSIC_FREAK1 May 10, 2009
    It's not charging, and my windowsmedia will not show that it is even connected, but it says on the player that it is, what can i do?
Just figured mine out. turn your clip off. put the slider in the hold or lock position. press and hold the center button on your clip. continue to hold while attaching the usb to your clip. keep holding the center button as clip powers up. after appox. 12-15 seconds, your computer should read the clip. i am running windows xp and this is the ONLY way my comp. will read the clip. but it works great!! good luck!
Posted on May 01, 2009
Under the settings -> USB Mode I switched it from Autodetect to MSC and XP recognizes it just fine now.
Posted on May 05, 2009
  • 66 Answers
There might be a sync option in the menu on your sansa that you must enable first. Look for that
Posted on Apr 23, 2009
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2gb not showing songs
Go to this guys tip it is a good tip on your problem, Fixya will not let me copy and paste, it so here is the link. Solve your MP3 Player Connection Problem.
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
I can't load the small disk on my desk top , how can i get the music i want on my sansaclip?
Open your sansa clip from its icon (might show up as removeable drive)
in the My computer section of explorer
dbl click it, this should open it up in explore, then just drag stuff to it
Aug 02, 2009 | SanDisk Sansa Clip MP3 Player
Can't add or remove music off my Sansa Rhapsody 2GB
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa Clip 2GB not detected by XP SP2
Change the USB Mode to auto-detect and see if you get better results. If that fails, switch entirely to MTP mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 2gb clip
While the player is connected to the computer, you will not be able to go through the menu, play music, etc. Only after you have disconnected it from the PC will it work.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
"refresh database"
Get the Vista compatible version of the software from Sansa's website
May 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa clip; Does not appear on icons
unplug Sansa MP3 player from your PC, go to menu ->settings, scroll down to USB-Mode, change mode from MTP to MSC, re-connect, yout PC will connect, detect new usb devive, disk drive.... and your sansa icon will be displayed at computer folder.
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
734 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
