Question about Odor Free Machines Ozone Generator Villa 1000
Not smelling the ozone anymore - Odor Free Machines Ozone Generator Villa 1000
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
New Lasko Tower Fan smells when we have it on the ionizer option? Is this smell toxic?
Ionizers generate ozone, that is the same smell that you would have near an electric motor or a copy machine. The smell is caused by electric sparks that occur during the ionization process. Essentially high voltage is applied to a grid, air passes over this grid and electrons jump off of it and into the air. They then attach to any particles that are present in the air and make those particles attractive to anything less charged than they are.
There is a limit to how much ozone an air ionizer is allowed to produce because ozone is a respiratory irritant and is not desirable to have in large amounts. Ozone also damages rubber. A commercial air purifier has to certify that it is in compliance with that law in order to be sold. The difference is that they can change characteristic based on how clean the grid is and how much humidity is present.
Jul 01, 2016 | Lasko 48" Xtra Air Tower Fan with Air...
Are there any tvs that do not have an ozone smell?
Smell of Ozone comes from the anode cap of picture tube based TVs. If anode cap is firm and good, there will be no ozone smell at all.
Jun 06, 2012 | LG 50PX5D 50 in. Plasma HDTV
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
No ozone smell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 19, 2010 | Ecoquest Flair Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Filters???
Ozone filters, they filter out the ozone produced by the copier. This reduces the ozone output, and smell. But ii also traps dust, if the filters plug up it can reduce copy quality as well as emit more ozone into the work space.
Apr 15, 2009 | Canon imageRUNNER C3220 Color Copier
Need a disasemble/reassemble diagram/instructions for a cf-51
Hi!
Im not sure that you will get rid of the smell even if you vacuum clean it, but i know HOW to get rid of the smell permanetly. I work with thing like that.
I will try to explaong for you in my poor english. There are companys who works with cleaning up after a fire, the go in, start up a machine and do a "Ozone cleaning". That ozone machine kills all the oxygen in the room and that kills all the smells there is in that room. So what you need is to either borrow a ozone machine or contact a company that do ozone cleaning. Its not expensive anf it take 24h . Do that and you will never again smell that fire smoke.
You can read about Ozone Cleaning here:
http://www.thebigclean.co.uk/
Nic
Apr 07, 2009 | Panasonic Toughbook CF-51 Notebook
THE WET DOG SMELL
try soaking the grid plate in ammonia
Jan 11, 2009 | Ecoquest Flair Air Purifier
No ozone smell
This generally indicates that the plate is cracked or not making proper contact. Pull the plate and look very closely as even a tiny microscopic crack anywhere on the plate will produce these results.
Nov 08, 2008 | Ecoquest Breeze AT Living Air Purifier
Odor Free Machines Ozone Generator Villa 1000 Logo
50 people viewed this question
Top Odor Free Machines Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Odor Free Machines Pool and Spa Expert? Answer questions, earn points and help others
