Question about Hitachi 53UDX10B 53" Rear Projection Television
Is there a Magic Focus function on 53XDF01B?
The service manual recommends an automatic digital focus using the Magic Focus button but even shows that the supposed MF button is the convergence button. The wiring diagrams also show a magic focus sw. Is the a button somewhere inside for this function or some other way to access it from the front?
  • rickyc840 Apr 25, 2009
    Unfortunately on this model the menu option is "convergence" which then instructs you to push the convergence button on the front panel. I was just wondering if magic focus was accessed by pushing a combination of buttons or holding convergence.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    MF button / option should be in Menu >>setting area.
    Genius:
  • Hitachi Master
  • 1,039 Answers
The correct model is 53fdx01b. There is a mogic focus button on the front of the set. Procedure for Chassis DP05F, DP05, HP11, HP12:
1. Press and hold the DIGITAL ARRAY or CONVERGENCE ADJUST button on front panel.
2. While the button is held down, then press the INPUT or ANT button on remote control.
3. The unit will now be in the DCAM.
NOTE:
1. Proceed with digital convergence adjustment.
2. Remember to save the correction data.
3. Units with MAGIC FOCUS only - Failure to initialize MAGIC FOCUS sensors after saving
convergence correction data will result in a STATIC (+) display when MAGIC FOCUS attempts
to run. The technician will then be required to access the service only switch behind the front
cover to get back into the DCAM to initialize the sensors, since the procedure to access DCAM
without removing the front panel, requires MAGIC FOCUS to be running.
4. To exit, press the POWER button on the front panel.
Posted on May 02, 2009
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    We cannot get the color to align. It appears like there is a blue or yellow background around words
    If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
    If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
    You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
    Mar 02, 2011 | Hitachi 57F500 57" Rear Projection...
    Magic focus problem
    in the menu first check if focus is set to auto or manual, need to be auto, if it is then pop off the front cover and acess panel with TV on cafefully press small button on signal pcb front edge, this is service mode, press pip mode,then pip channel after intialize turn TV off then on, function should be restored.
    Aug 09, 2009 | Televison & Video
    Will not show red color in picture, magic focus shows red though
    You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
    Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
    SONY DSC-H1 focus problems
    I think the reason for that is that you are using a wrong focus type. I recommend you using wide focus (not sure if named it right) and make sure you have your steady-shot function on. To change focus type, just find the button next to the shot-button.
    May 02, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
    Magic Focus does not work.
    Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
    with upgrade Stk394-160E Hitachi part # CZ 01341,change both
    for reliability.....check B+ feed resistors for over-heating....T.
    Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
    TV automatically turns magic focus mode on when the power button is pressed on the remote and even manually.
    I have this problem starting today. Unfortunately, others who have fixed it have done the following.
    * Unplug TV for hours and it worked
    * Buying manual switch to the outlet or surge protector and switch power off that way.
    It appears that I'm in no mood to spend hundreds to get this fixed for hundreds of dollars and just going the Radio Shack route of buying a switch which would probably be more of savings. But needless to say, I hope that is the only problem I have.
    Sep 27, 2006 | Hitachi 46F510 46" Projection HDTV
    Will not auto focus
    "... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
    Nov 11, 2005 | Nikon F4s 35mm SLR Camera
    Switching from auto to manual focus
    AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
    Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
    Focus modes
    There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
    Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
    Hitachi 53UDX10B 53" Rear Projection Television Logo
    288 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
