Question about Fisher and Paykel GWL11 Top Load Washer
Model 110.2002201 wont spin out and lid locl wi model 110.2002201 won't spin out and lid lock light flashes while its washing replaced lid lock and control board still didn't fix it
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
  • 251 Answers
SOURCE: Hello, my MW511 Fiisher and Paykel top loader
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Posted on Jun 30, 2011
  • 251 Answers
SOURCE: washing machine won't go thru spin cycle. Lid
Hi there the lid lock switch is faulty and needs to be replaced - cannot be bypassed unfortunately.
Posted on Jul 15, 2011
KevinWhite
  • 1902 Answers
SOURCE: washing machine will fill with water but then
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Sep 03, 2011
Jahn27
  • 1554 Answers
SOURCE: Washing machine model mGM612 has
The problem can be determined through the Wash Progress LEDs. The specific lit LEDs combination indicates an specific error code that tells what generally the problem is. But the exact positions of the lit LEDs are necessary in determining the exact code. Refer to the illustration below and post back the code or the exact positions of the lit LEDs. You may Google for the error code once you determine it, like "Fisher and Paykel Fault Code 37".
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not bar you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Sep 06, 2011
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
Washer won't spin or drain
if it can't drain then it won't spin,something could be jammed in the pump,the clutch isn't falling on the trans. what does it do when it goes into spin cycle'do you hear any noises.when it does go into spin cycle listen if nothihng hapeens open the lid and close it listen to see if the clutch falls
Mar 06, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Fisher and paykel model no GW611 washes but won't spin nor lid locks
Sounds like the lid lock has gone bad. Check the wire connections to it and if you should need to order the lock, here is their website.
Nov 05, 2012 | Fisher Paykel EcoSmart GWL15
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
Nov 21, 2011 | Washing Machines
Washer wont cycle
Number 11 is your lid switch. It is very easy to repair. To test it watch the video.
Older models would wash with the lid open but not spin. This later model washer won't wash or spin with the lid open so I suspect you have a broken lid switch. IF that turns out not to be the case then I would next check the motor start capacitor. When these fail the motor won't work at all.
On your machine you gotta have a long skinny screwdriver . On the back side of the washer you back out a screw on each side and then she pops up.
I gotta whole page of stuff on these washers HERE
Nov 01, 2011 | Estate TAWS850PQ
Won't spin
If a washer will agitate and wont spin check the lid switch. Lid switches are designed to not allow spin on most washer but will allow agitate. Safety feature.
If you need further assistance please feel free to comment me back.
Jul 27, 2011 | GE WBSR3140DW Top Load Washer
Centennial washer, will fill with water, wont spin or agitate, power is good
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Apr 30, 2011 | Maytag Centennial MTW5800TW Top Load...
My washer wont spin, it washes but then it wont start the spin cycle.....please help
what is the model number and the brand name?most likely you have a bad lid switch.it's a saftey on most washers,the factory doesn't want the washer to run when it's in spin so if you were to open the lid while it was spinning the washer would shut down,if the lid switch is broke it's like the lid is open and it won't spin or run
Jan 23, 2011 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
47 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
