Question about E-Machines Computers & Internet
EMachine E443 reboot F key - E-Machines Computers & Internet
Fix my pc
It helps if you describe the issue
Mar 18, 2014 | E-Machines eMachines Desktop PC
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
Is it possible to downloan a movie for my sony nwz-e443
You can download a movie to your computer and then copy it to your player, most likely it won't play on your MP3 player unless the movie file is converted to a file format that suits your MP3 player.
http://www.fixya.com/support/r5874192-play_videos_mp3_player
Feb 03, 2011 | Sony NWZ-E443 Digital Media Player
Cannot get into bios on emachines t6410
i believe it is the f2 key right after you see the big e at start up timing and patience
hope this helps and please vote
Nov 30, 2010 | Gateway Computers & Internet
After installing restore dvd for emachine t3256,
take out any disk's floppys ect that are still in the computer firstly if this fails then windows mybe completly broken and require a full re install if this answer helps please rate it
May 13, 2010 | E-Machines eMachines Desktop PC
MY EMACHINE DESKTOP RECOVERY CD DOENT WORK
Hello
When booting up pc have you held the delete key or f2 key down to bring up the boot menu?Should be a option of cd dvd or hdd to boot first.
You want the cd dvd boot option on top or first.tThen reboot pc.
When asked hit any key to boot from cd, hit a key.Should start install.
If youve done this, clean the dvd or cd install disc with some windex and a paper towell,try again.
You can also do a system restore from control panel recovery option.
Jan 23, 2010 | E-Machines eMachines Desktop PC
I have an old second hand emachine
make sure to boot from the cd by when you turn the computer on press ESC key or the f1, f2 or f12 key one of those will you boot from the CD
Sep 03, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
21 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
