Question about Panasonic AG-456 Camcorder
Panasonic ag456 I just bought a new panasonic ag456 I connected the power adapter but there seems to be no power. The light for the power adapter isnt turning on. As a matter of fact I bought two of these cameras and they seem to be doing the same thing. Neither one of them has a battery connected to them could this be causing this problem.
    Champion:
  • 221 Answers
These camera should operate with only the adapter, but they are notorious for having broken solder connections on the rear board where the audio and power connectors are. disassemble the camera and re-solder the connectors on the board; you may need to add a little epoxy glue to help hold the audio connectors.
Posted on Oct 19, 2007
SOURCE:
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
All of sudden the xbox wont turn on, never had problems before
well if you press the power button and light isnt on check plug connection going into console and then from console it goes back into the ac adapter. make sure its plugged in tight. To make sure ac adapter is working fine there is a small light on the side if it is green it is working fine if it is either orange or red you have a problem and may need a new adapter. If so you can get a new/used one from your local game store. hope this helps and good luck
Jan 07, 2011 | Microsoft Xbox 360 Console
I have a panasonic toughbook cf-48. It was working and then all of a sudden it shut down and won't turn back on. I thought it was that the battery wasn't charging, so I bought a new battery. When I looked...
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 25, 2009 | Panasonic Toughbook 48 Notebook
My xbox a adapter is plugged in but it isnt
if it isn`t lighting up then please try the adapter with some other computer and if it still doesn`t light up then it`s faulty.you need a new one.
Jul 12, 2009 | Microsoft Wireless Network Adapter Xbox...
Possible blown motherboard
you need a fully working battery as while you plug power adapter power light does not come on nor does the laptop itself turn on please check the power supply and its cord . If you have have not grounded the power supply third terminal this is possible that power is coming from body of your laptop.But check DC voltage output of power adapter. It should be approximately18 to 20 volts
Jul 10, 2009 | Panasonic Toughbook 19 Laptop Convertible...
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
Dell latitude c510/c610 wont turn on
Ok. Try the below steps.
1) Remove the batter and power adapter. Remove the CD/DVD Drive and any other connected devices like pen drive or mouse.
2) Now hold the power button for 30-40 seconds. Release it.
3) Now connect only the battery and try powering on. If no luck, connect the power adapter and check. (till now do connect the CD Drive - It can be a issue with the drive as well)
4) If no luck, you can try removing the RAM from the laptop and fixing it back.
5) If no luck, contact Dell Support for Replacement of Motherboard.
Apr 16, 2009 | Dell Latitude C510 Notebook
Can I use Panasonic AG456 camcorder on PAL system ?
le istruzioni che ho scaricato parlano di NTCS sistem
Ma in editring si pu? convertire in pal con power director oppure usando un software di conversione anyconverter pal
Dec 06, 2008 | Panasonic AG-456 Camcorder
Dell Latitude CPi has no power and lights will not come on when connected.
If you bought a new battery and connect the powercable and still nothing happens it's usually a problem with a fuse. If not a fuse it's usually the cpu. If the problem is with the vga the lights usually turn on. Difficult problem. This depends on how fare you want to go and able to spent.
good luck
Nov 28, 2007 | Dell Latitude C610 Notebook
Panasonic AG-456 Camcorder Logo
242 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
