Question about Panasonic KX-TG5439 5.8 GHz Dual Handset Cordless Phone (P02120)
Reset my panasonic cordless phone
I need to reset the phone. The help desk at panasonic said take the battery out for at least one minute, but that didn't work. Under the battery you can peer through and see small sections of the circuit board, and I am betting that bridging one of those electronic gaps would reset the phone, but i don't know which ones. Can you help me.
  • 8 Answers
SOURCE: Dropped calls when cordless phone plugged into it.
I have solved this problem several times by using a splitter at the telephone jack instead of the XDP port on the phone. The extension is programmed to share the port isn't it? That is in program 600.
Posted on Sep 16, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: panasonic cordless phone no dial tone changed batteries
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Posted on Nov 22, 2009
HelleP531
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
Posted on Feb 11, 2010
I nd to unblock a phone number.
you need to remove the battery hold down power button 2-3 sec look for reset hole (very small) press a cocktail stick in holding for a sec then you should be good to go, if you can not find a reset hole then you will need to take it apart and either connect internal clock battery to same wire for a sec or look for reset hole hidden by plastic case hope this helps
good luck
Oct 12, 2013 | Panasonic KX-TGA652B Cordless Phone 2 Pack
The battery charging light is on constantly. The phone is a , KX -TG2357
Try reset your cordless phones in particular, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this process will help reset the phone and help fix all abnormalities. If the problem still persist, unplug the phone for some minutes, now repeat the steps.
Jul 06, 2011 | Panasonic Cell Phones
How do i reset my cordless phone after a power outage
Most cordless phones can be simply reset by taking it out of the base and removing the battery. Put it back in after a minute. Note that you may lose your contacts on your phone when you reset it using this procedure.
Nov 30, 2009 | Uniden Cordless Phone
Panasonic KX TG9331 no link to base Even standing next to the base, I cannot answer the call. Sometimes repeated pressing of the talk button lets me talk. Also, switching to speaker phone sometimes drops...
Sounds like a defective handset or base unit. Unplug the base unit from power and the telephone jack. Leave unplugged for 1 minute, this sometimes helps the phone to reset from a problem. Unplug the battery from the handset and plug back in after a minute also to help reset. Place your handset in the base unit for about 1 minute to allow the handset to link up with the base unit. If this doesn't work you may have a defective phone. Contact Panasonic support for further information if this does not work.
Aug 29, 2009 | Panasonic KX-TG9331T Cordless Phone
RESET PASSWORD
inter this code: 726276642
Feb 16, 2009 | Panasonic KX-TG1033S Cordless Phone
Digtal answering machine not working.
I don't know yet if this is a resolution, but I'm going to try this tonight. Unplug all bases and remove all batteries from all handsets -- leave this overnight.
Here's the history of my problem. I rec'd this phone for my birthday. 3 weeks in, power went off in my building and answering machine part stopped working. I took it back to the store, and they gave me a new one. 4 weeks in, another power outage and I have the same problem. I called Panasonic, and they told me to unplug all bases and remove the batteries in the handsets for 'a few minutes' to reset the units. I waiting 10 minutes, and replaced all batteries and plugged in all the bases again. No luck, answering machine still did not work. I noticed, however that the phone did not reset as I still had all my phone numbers and caller id history.
I called my brother who is an electrician, and he advised me that the base has a 'capacitor(sp?)' and it will probably take a few hours for it to 'drain' so the phone will reset itself. His suggestion is to unplug all the bases, remove all the batteries and leave everything OVERNIGHT. By that time, the power store in the base should hopefully be wiped out and the phone should reset like new. I will try this tonight and let you know if this works.
Jan 31, 2009 | Panasonic KX-TG1033S Cordless Phone
How do you reset the Panasonic KX-tg2631?
To reset the base station, simply unplug the power from the wall. To reset one of the phones, remove it's battery. Owners manual located at http://service.us.panasonic.com/opermanpdf/KXTG2631W.pdf
Jan 08, 2009 | Panasonic KX-TG2631 Cordless Phone
System pin reset
try using all zeros usually 5 zeros
Dec 01, 2008 | Siemens Gigaset 2420 Phone
System pin # reset
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Panasonic KX-TG5439 5.8 GHz Dual Handset Cordless Phone (P02120) Logo
2,419 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
