Question about Carrier Refrigerators
Unit flashing alt aux - Carrier Refrigerators
Annoying display
jus pres display on the remote or the unit.
Nov 14, 2013 | Sony Car Stereo Cdx-gt564ui Cd Mp3 Aux In...
I just bought a 1989 minnie winnie Winnebago with Chevy chassis, there was no generator all wires leading to generator were disconnected. There is no power to the rear cab unless the engine is running. The...
The wires that were hooked to the Generator were also hooked to the aux batteries. you'll have to trace the wires that are disconnected. Also, if you plan on just using your alternator to keep the aux batteries charged, then you need to make sure you have at least a 100 amp alt, If you use the batteries while the van isnt running it takes a big toll on the regular 60amp alt that most of these vans come with. I'd buy another generator and hoo it back in myself.
Oct 29, 2013 | Cars & Trucks
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
May 11, 2013 | Sharp Heating & Cooling
Universal remote programming code for str de697 reciever I am trying to program my ATT uverse remote to operate this reciever.
Here are the list of Sony remote codes :
5017, 5023, 5028, 5029, 5030, 5031, 5032, 5033, 5095, 5096, 5097, 5113, 5117, 5121, 5125, 5129, 5133, 5134, 5136, 5146, 5162, 5163, 5169, 5170, 5171, 5172
Here is how to program the remote.
  1. Turn on the Receiver.
  2. Press and hold AUX and OK at the same time.
  3. Release both the AUX key and the OK key at the same time. All the Mode keys should flash twice.
  4. Enter the four digit setup code and the AUX key will flash three times indicating correct entry and return to normal operation.
  5. Point the remote at the Receiver and press the power button. If it turns off the receiver it is now programmed. If not Repeat steps 2-5 until the remote turns off the unit.
Good Luck,
Robert
Feb 27, 2011 | Sony STR-DE697 Receiver
My Apple Iphone doesn't work with my B&W Zeppelin (There's no compatibility). How can i do? Thank you Luana from Italy
1) have you the latest software on your zepplin?
2) does the unit work with any other ipod? if it does then it may be your unit.
if it does not, check aux mode, if ok on aux, then it could be a docking arm problem.
3) does the light (led) go blue when the i phone is in the docking arm, if not, then again it looks like the docking arm.
if the red light flashes when putting the iphone in, then the unit has the problem power supply, so contact your supplier or b and w service.
hope this helps.
Jan 22, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
Horn aux outlet cruise dont work
the horn and aux outlet use the same power circuit, I bet if you actually take the fuse out and replace it with a good one it will work.
I am assuming that you just looked at the fuses, sometimes a bad fuse will look good, but transffer no current.
Feb 02, 2010 | 2003 Ford E150
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
Cannot find a device code for ATT Uverse DVR cable box
1. Release the volume controls and assign them to the AUX: A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
Dec 28, 2008 | Bose Cinemate Digital Home Theater System...
Refrigerators Logo
41 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
