Question about Samsung PN50C7000 50 in. TV
Black horizontal line across lower part of screen. It was a very thin line and now doubled in thickness.
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
  • 117 Answers
SOURCE: thin black line across the bottom of the screen
buffer board/can be repaired or new buffer
Posted on Apr 20, 2010
sodeep
  • 3267 Answers
SOURCE: screen has black horizontal lines across the
panel needs replacement, better go for a new tv
Posted on Dec 25, 2010
SOURCE: 2 thin horizontal black lines all the was across
ON THE EXTREME LEFT SIDE OF YOUR TV FACING BACK OF TV WITH COVER OFF THERE ARE TWO BUFFER BOARDS UPPER AND LOWER WITH WITH MANY FLEX CONNECTERS CLEAN THESE CONNECTERS WITH CONTACT CLEANER UNPLUG FLEX CONNECTER BEFORE CLEANING CONNECTER ONLY DISCONNECT CONNECTERS THAT ARE ADJESCENT TO HORIZONTALE LINES THESE CONNECTERS ARE NOT EASY TO DISCONNECT AND RECONNECT IF THIS DOES NOT SOLVE PROBLEM PANEL IS DEFECTIVE tombou300619_2.jpgtombou300619_3.jpg
Posted on Feb 28, 2011
SOURCE: Samsung hp-r4252 Pictures appeared to be
DEFECTIVE DATA BOARD BUTTOM LEFT AND RIGHT FACING BACK OF TV
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Why does my SAMSUNG PLASMA have thin black line? horizontal line How to fix?
Sustain board fault. Contact any service technician. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Samsung PN64D7000 3D Plasma TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
Thin horizontal black line appeared lower half of
Fixed non moving lines usually means you have a problem in the panel display or t-con. If it is in warranty get it to a factory authorized service center. If not you can try to change the t-con and see if this fixes the problem, if not then it will be the panel it's self and will be cost prohibitive to repair.
Sep 01, 2009 | Televison & Video
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Samsung PN50C7000 50 in. TV Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
