Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
I would like my airconditioner to go below 60
I have a window airconditioner that only goes down to 64 i would like it to go lower.Can anyone help?
  • Lou Barta May 11, 2010
    A/c's are really not designed to cool below 70 degrees. If you are getting anything lower than that you are lucky. Now if this was a central air conditioning system you could have your contractor install a "low ambient control kit". I do not know of one designed for a window unit. (I do not understand why you would want it so cold).... As a last resort you could install oversized window unit. It may lower the temp to your wish. But it will not pull out the humidity. It will be cold..... but moist. Like a cold damp basement. I do not think that you would find this desireable.
    Good luck..................
Diagram wiring
You could replace the Thermostat with one that allows you to to set it lower, or get a different humidistat that goes from 0-90 , There is always ways around, Thus this great website.
If you need more details or where to purchase let me know.
Oct 10, 2013 | Danby DPAC12099 Air Conditioner
How do i charge the airconditioner
On a Traverse the low side service port can be found on the return tube between the radiator and the engine down by the compressor. It is almost directly below the high side port ( about 2' below it).
Sep 01, 2012 | 2010 Chevrolet Traverse
When the airconditioner is on cool.Water comes from the airconditioner inside and dripping on the floor.
If it's a car air conditioner, your condensate drain line is clogged. If it's a home window unit, it needs to be tilted outward more. The downward tilt should be no less than 1/4" per foot. If your unit is 18" from the window to the back of the unit, the back should be 3/8" lower that at the window....minimum.
May 14, 2011 | Mitsubishi Heating & Cooling
Every time i start my 98 buick regal ls my drivers window goes down
The only wiring schematic I could find for your car is for the 2000 Buick Regal, but I hope this helps,
since it gave me a reason why starting a car would cause the driver's power window to
go down, and no other window in the car - it has a special circuit component
(the "Express Down Module").
Its possible that the Express Down Module in the power window switch circuit has failed. This
module latches the "Express Down" switch in the "made" state until released by the "Express
Down Module." If the Express Down Module is latching the Express Down switch when it
shouldn't (at power-up) instead of when it should (at the window "down" limit), then the driver's
window would lower when the driver starts the car. The way to tell if this is the problem is to
note how fast the driver's windows goes down - if it goes down ALL THE WAY, then you know
that the "Express Down" circuit is involved (and therefore suspect the Express Down Module).
If the driver's window only lowers part of the way, then the Express Down circuit is exonerated.
See the various components of the driver's power window circuitry in the
2000 Buick Regal power window circuit schematic below.
Apr 18, 2011 | 1998 Buick Regal
Won't install in windows with 64 bit system
Please ensure you have an updated 64-bit driver specific to your operating system from the link below.
Canon PIXMA iP1600 Printer Drivers
Select your OS and then download the correct driver.
You can find your OS type by clicking on the "Start" button (lower left), then right-clicking on "My Computer" or "Computer" and selecting "Properties".
I hope this helps you get it installed. Have a nice day!
Apr 06, 2011 | Canon PIXMA iP1600 Printer
99 olds interigue airconditioner went bad can i by pass with out affecting anything else
yes you can but you will not have air do the 60 40 rule drive 60kmh with 4 windows down?make sure the belt is still around the air conditioner if sqeaks spray wd40 directly on the pulley
Feb 16, 2011 | 1999 Oldsmobile Intrigue
I have a 99 grand am this summer i used the air conditioning, and very little cool air came out, alittle more when the car was going down the road. Now, it is cold outside the heat is doing the same thing....
Check to see if the intake for your heater core/ airconditioner is blocked. Its sometimes located on the passenger side of the car. Below the windshield. Sometimes there is kind of a grill below the window behind the hood. Make sure its not clogged full of leaves etc. You need outside airflow through that hole to go through your heater /airconditioner core to give you heat in winter, cool air in summer.
Jan 25, 2011 | Pontiac Grand Am Cars & Trucks
I need to get 64 bit driver for canoscan 4200F the file is no longer on the canon usa site and on the canon uk site it fails to download at the "accept licence" page. I also need the 64 bit canoscan...
Are you looking for the Window XP 64bit drivers? As those are not listed on Canon's support site but the Vista and Windows 7 64 bit drivers can be downloaded from the support site link below. The ScanGear software is also available on the USA site.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=10445
Robert from Blitware
Jun 16, 2010 | Canon CanoScan 4200F Flatbed Scanner
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Oct 23, 2009 | Microsoft Excel for PC
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
185 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
