Question about Nelson L R 56610 Electronic Water Timer
My system only runs a few minutes and turns off
Bravia klv 32ex300. Runs for a few minutes, then turns off. Restarts twice then turns off and won't restart. What's wrong?
most common problem is main filter cap aster which is in power board if find defective please change but if its ok then replace main board because system ic internally leaking
Aug 29, 2015 | Sony Televison & Video
Dash board goes dead
1) check and see if your car has a good earthing cable.
20 it could be a loose terminal or fuse.
Mar 15, 2014 | Winnebago 2008 Voyage 32H
Air conditioner fan wont start
change run capacirotor of outdoor fan motor.
Jan 07, 2014 | LG LSC121PMA Split System Air Conditioner
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
When I turn my computer on it boots up just fine & monitor works. At some point, sometimes a few minutes, sometimes a few hours the monitor will go black and I get a no signal message. The system is...
would appear the system is in standby mode you could disable this
in windows 7 or vista go to
start
control panel
power options
choose when to turn display off
Sep 05, 2011 | Gateway Computers & Internet
The unit will turn on and run fine for a few minutes then shut off. It won't immediately turn back on, almost as if it hans to cool back down first. Any ideas i have a lennox furnace
The ignitor will light, the blower will start up and run for a few minutes and then the system will shut down, and the blower will continue to run and cool down. The ignitor is not working properly, the ignitor has carbon build-up and need to be removed, cleaned all the black carbon from the ignitor with a little piece of sand paper and replaced, turn the heat back on and this should correct the problem.
Dec 12, 2009 | Heating & Cooling
A/C not working properly
There is what is called a low pressure switch in the system that will not allow the system to run unless there is a complete charge in the system, what is happening is that the system is "Short cycling" due to low pressure, you can purchase a re charge kit at the local Autozone or Pepboys and that will fix the problem.
Sep 04, 2009 | 2000 Volvo V70
Cooling fan runs continuasly even with ignition is no switched on
Even when the key is off with the engine cool after a few minutes? Or just a few minutes after it is turned off with the key?
Check or change your thermostat and flush the radiator with the heater running on hot as it can be. Can you see inside the radiator? If you can is the water flowing good? If it is not after you change you thermostat and it still runs hot then it is your water pump. Is it running hot?
Please answer the questions before you rate this.
Jun 22, 2008 | 3Com Fan tray - for Switch 4050 / 4060
Nelson L R  56610 Electronic Water Timer Logo
24 people viewed this question
Top Nelson Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Nelson Hardware and Accessory Expert? Answer questions, earn points and help others
