Question about Garden
Craftsman 917254241 Need schematics for belts, idlers and complete "under the mower" for craftsman model 917254241
SOURCE: Craftsman Model 917.276641.
Do you see a belt diagram posted on the deck somewhere? If you do follow it. One very important thing to remember with belts is the v-pulleys accept the v-portion of the belt and the flat pulleys accept the flat side of the belt. If I can be of more help please feel free to mail me.Donnyb60
Posted on Mar 18, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
  • 376 Answers
SOURCE: belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Posted on Jul 29, 2009
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to tighten a craftsman LT1000 belt ?
There is an idler pulley that engages the mower deck and tightens the belt automatically on your model. Check to make sure the belt is routed correctly, return spring is in place and that your cable is operating smoothly.
Jul 19, 2014 | Craftsman Garden
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Drive belt for 46" mower deck jumps off
The tentioner could not be applying the right preasure. Make share it is not sticking and that it is moving free.
Jun 22, 2013 | Craftsman Garden
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsmen 5000 Model # 917276071- manual transmission: mower will not take off normal, it will pull off at a very slow speed going forward, and a little faster in reverse. The idler pullies are fixed,...
I do not know of any tractor that has a fixed idelr pully!! The purpose of the idler pully is to take up the slack in the drive belt. What scamadic are you talking about? Is it the one on the deck? If it is that one you have the belt installed wrong. The idler pully has a large spring on it and is flat, not "v" shaped szm230
Apr 15, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
CRAFTSMAN Tractor Model%23 917257643 adjust idler pulley. I have the above lawn tractor. One day the mower belt shredded. I got another one and when I engage the mower it starts to shred. I think I need to...
First things first! Before you installed the new belt, did you check the blades and idler pulleys to see if they all turned freely with no resistance while the belt was off and the blade brakes released? Release the blade brakes by engaging the handle with the engine off!
When you installed the new belt, did you put the back side of the belt against the flat pulleys and the inside of the belt in the V-pulleys? Did you double check to make sure you didn't inadvertently miss a belt guide getting the belt on the outside of it instead of underneath it. Did you look at the picture in your owners manual to make sure you had it routed correctly and make sure it is not rubbing against anything when you have the blade lever engaged? CHECK THIS WITH THE ENGINE OFF If you don't have your owners manual, look under the foot boards on the tractor, many of the Sears tractors have the routing diagrams there. If it is not there you can go to searspartsdirect.com , enter model number 917.257644 (NOTE the number difference) and look at the picture of the deck, it shows what the belt should look like when it is installed. You can also download an owners manual there. As best as I can remember, there is no adjustment for the idler pulleys.
Oct 25, 2009 | Craftsman Garden
My Sears 917.272911 Lawn Tractor is eating mower drive belts. The belt is being worn out in minutes on the flat idler pulley side. When I put the old belt back everything seems to work fine. The new belts...
There's a couple of things that could be causing this. First, make sure the idler pulleys and blade pulleys spin freely. Second make sure the belt is behind the belt keepers on the two idler pulleys. There is only one on the left idler, but TWO on the right idler. I suspect that is your problem. Anyway, once the belt is on, engage the blades, with engine OFF, and inspect the belt routing, making sure it's not over or under something it shouldn't be.
Jul 02, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Need a belt diagram
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.273638&pop=flush Enter your model # and search, scroll down to mower deck, and there ya are.It's an easy one. Straight across the back between the blade pulleys, then to the inside of both idler pulleys, then to the engine pulley. Hope this helps. Dwain
May 23, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
