Question about Samsung YPT9 Digital Media Player
My Screen is stuck on "transferring not disconnect
I was downloading files to my MP3 player. I was sure everything was done and complete. I unplugged my USB cord and now my scrren is stuck stating "Transferring files...Do not disconnect.". Is this a quick fix? Did I ruin my MP3? Help!!
  • 1 more comment
  • meapimp123 Aug 05, 2008
    i need help it is frozen on transferring not disconnect and someone disconnected it wat do i do???
  • johnteckle Aug 05, 2008
    when i try to delete files from the samsung yp-t9 it doesnt work and wont delete the files
  • Anonymous Mar 20, 2014
    cannot connect i beat to pc with usb
Monalysa is rite thank u so muchhhh
Posted on Aug 01, 2008
Hold down the record and the menu button simultaneously... that should restart it. There's a topic about this that has already posted, hope you find the answer here or there.
Posted on Sep 28, 2007
Updating the firmware should be done for this type of error: For PDF instruction you could download this by doing below: 1. Go to 2. In the right side of the page type MP610 and hit Enter 3. Click MP610 Firmware Update for File Sys Error 4.Unzip file and read the procedure
If you have no time to download pls perform the ff: File Sys Error This is a system firmware update. This update will fix the "File Sys Error" message and restore the MP3 player back to the factory settings. The firmware update file can be downloaded at Important This procedure will delete all contents on the MP3 player. Please make sure that you back up all your documents before proceeding with the firmware update. To backup all contents on the MP3 player, simply connect the MP3 player to your computer. The MP3 player will be listed under "MY Computer "as a removable disk. Double-Click on the removable disk and copy and paste all the folders/files on your desktop.
Firmware Update Procedure Do not have any USB Devices connected to the computer including the mp3 player. - Download the firmware file from our web site. The file will automatically run itself once it is done downloading. The below screen will appear. Do the Following: 1- Connect the MP3 player to your computer. It will show up in the number one box in the firmware update software.The windows explorer bar will also pop up when you connect the mp3 player to the computer. Simply close the explorer bar. 2- Once the MP3 player shows up on the number one box, click on the "Firmware Feature" icon to start the firmware update. 3- After the firmware update has been completed, you will receive a check mark in the firmware number one box. Disconnect the mp3 player from the computer. Close the firmware update software. Turn the MP3 player on. If the mp3 player reads Coby, then the firmware update is successful. Use Windows Media Player to transfer your music files in the mp3 player. This will restore the Artist, Albums..etc selections in the Music menu. If you have a problem with this device, please read the troubleshooting guide on the user manual or visit us on the web at for Frequently Asked Questions (FAQs). If these resources do not resolve the problem, please contact Technical Support. Phone: 800-727-3592 Weekdays 8:00AM-9:00PM EST Weekends 9:00AM-5:30PM EST Weekdays 8:00AM-5:30PM EST
Feb 18, 2011 | Audio Players & Recorders
My player starts to load, but then doesn't completely turn on or
Try this 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 01, 2009 | SanDisk Sansa e260 MP3 Player
I cannot get music to load on to my coby mp3 player
Downloading/Uploading files
1. Connect the player to PC.
2. Open WindowExplorer on PC.
3. Select the file to save and drag-and drop it into the
removable disc icon. You can also transfer file fromthe
player to your PC.
Do not remove the player while it's transferring files.
It might currupt or damage the firmware and or files
on the player. If the player is accidently removed
while transferring and does not work properly,
remove battery for 3 seconds and replace it.
Disconnecting the Player
After completing the file t ransfer, you must disconnect the
player as following direction:
Double-click on the green arrow in the taskbar on the
bottomright of the window.
When the [Stop a Hardware] message appears, press the
[OK] button and disconnect the USB port.
Dec 02, 2008 | Coby MP-C827 MP3 Player
Cant transfer limewire music from my computer to my mp3
We have the same player. Just found out that iTunes are not compatible with the player, as they are m4p files. Make sure you have mp3 files only, or can convert them. Good luck
Nov 08, 2008 | Audio Players & Recorders
YP-T9J Screen stuck on transferring files do not disconnect
Vegggie Boy is mistaken. You should press and hold the red record button while pressing the menu button. The player will reset itself to normal operational mode.
Jun 14, 2008 | Samsung YP-T8 Digital Media Player
Help i have a Samsung YP-T9 and it froze
hold down the menu and play button at the same time to reset, should turn it off, then just turn it back on again
Jun 11, 2008 | Samsung Yepp YP-T9 Digital Media Player
Ilo mp3 player wont work right! HELP!!!!
Make sure the song is in mp3 format
Mar 10, 2008 | iLO MP3 Player
MyMusix PD-6110 MP3 Player wont play any songs
Unfortunately, your files must have gotten corrupt. This issue is most prevalent if you disconnect the mp3 before it has completed the transfer of songs.
To fix it, format the mp3 by plugging it into the USB port, right clicking the drive that is displayed and choosing "Format". This will remove all songs from the mp3 player. Afterward, you can re-add any songs that were lost. But make sure when disconnecting, you see no loading animation on the screen. Then right click the "Remove Hardware" icon on the bottom right of you screen, choose "Stop". Check again for a loading animation on the screen (if there is one, wait until it stops), and you can remove the mp3 from your USB port.
Jan 23, 2008 | MyMusix PD-6070 MP3 Player
My screen/mp3 is frozen
Press and hold A-B button and menue button at the same time.
Dec 01, 2007 | Samsung Yepp YP-T9 Digital Media Player
Songs won't Sync
To enter recovery mode:
1. Make sure the hold button is on, (look for orange) and hold down the record button and plug into the computer.
2. A 16MB Format drive should appear in My Computer under Devices with Removable Storage, you are now in recovery mode.
Now download the following File:
Run the file after downloading and follow the on screen instructions, making sure to connect your player in recovery mode.
Make sure you select the option to Format when giving the option.
after running the program, remove hold from on top of the player and disconnect the player when completed and completion should be set for the player.
After running this, try downloading songs again. Remember to make sure you authorize your player and ensure that the songs being transferred are available for transfer.
Mar 27, 2007 | SanDisk Sansa e200 MP3 Player
Samsung YPT9 Digital Media Player Logo
114 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
