Question about Baby Gear
Folding triton trekker pram - Baby Gear
Looking for a replacement for the folding mechanism of a p&t vibe 1
Hi
I was wondering what side clip you are missing???
It has been ages since you have posted, not sure if still searching???
Nov 30, 2012 | Regal Lager Phil & Teds Vibe Jogger
Pram keeps folding while being pushed
Hi, This definitely sounds like the gas cylinder is gone. You'll need to return it to your retailer, or contact www.quinny.com to arrange a repair. Hope this helps.
Oct 05, 2012 | Quinny Buzz Jogger
Can't fold pram
Hi, I believe you activate the folding mechanism by pushing down on the two grey rectangular plastic buttons on the black side hubs (at the mid point of the pram).
In any case you can download the complete instruction manual for the pram for free at http://www.freebabymanuals.com/quinny/prams
Hope that helps.
May 26, 2010 | Quinny Buzz Jogger
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Bought a second hand mamas and papas pilko 3 combi puchchair and car seat need some instructions on folding and opening , that i could print off ?
Hi there, you should find the one you want on this website:
www.mamasandpapas.com/product_manuals.php?f=Prams-Pushchairs
Sep 26, 2009 | Combi Baby Gear
Can this be folded down to fit in a car boot in pram mode
I assume that you mean when the pram is in the bassinette mode (for a newborn)?
The answer is yes. I would suggest that prior to folding, ensure that the pram is laying completely flat and that the hood is folded down flat too.
I hope this helps.
Sep 25, 2009 | Silver Cross 3D Stroller
Problem in folding quinny buzz to stiff
I would suggest that when folding the Buzz, stand in front of it first. Push down one of the grey buttons, then slide and push the other, then you can use your whole body weight to push the pram to the floor enabling you to collapse it. It is also easier if you remove the seat prior to folding.
I hope this helps.
Jul 08, 2009 | Baby Gear
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
Baby Gear Logo
61 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
