Question about Canon PowerShot A310 Digital Camera
Blurry images when I take a picture it comes out blurry, do i need to reset it? How?
  • clue less Nov 24, 2007
    When I turn the camera on the lcd screen is blurry and the pic are to.But the pics I have saved on my card are clear on my LCD sceen.I have cleaned the lens but it didnt help.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 19, 2007
SOURCE:
My picture is blurry,and words are blurry,what do i do
A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Jan 24, 2015 | Televison & Video
Pixeled picture, Red color, blurry and smeared images
Ghost image and snowy colorful pixelation with vertical black bars? You can try a hard reset by unplugging the unit completely for 4 hours. However you may have a prob with the YSUS and the YBU-L (YBuffer Upper-Lower.) Perhaps even the Logic Main may be defective. If you are still under warranty take it to a service center ASAP. If not Get out your Voltometer. You can email me for some help...
[email protected]
May 08, 2009 | Philips Televison & Video
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
Blurry images on camera
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
Why are the picture all blurry
Have you tried to reset the camera back to factory default settings? To do that: go to the Menu left arrow to reset and press ok. Highlight Yes and press Ok. This will reset the camera back to the factory settings see if the images still come out blurry.
Mar 24, 2009 | Olympus FE-170 Digital Camera
Finepix A350 - everything is blurry
I had the same problem. I tried a reset in the camera, also reformated the card through the camera once I had done a reset. At present it seems ok.
Aug 17, 2008 | Fuji FinePix A350 Digital Camera
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
Sep 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Blurry images 40 F2.8
This is a known problem I believe due to a bad batch off CCD.s Tell Sony Technical support about it. If this camera falls into the above category it will be replaced free of charge
Jul 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Canon PowerShot A310 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
