Question about Acer Aspire One PC Notebook
I turn my acer on and it just goes over and over to recovery and it wont boot. i have tried to press f8 and it wont let me just does the same thing over and over nothing seems to work can anyone help
I turn my acer on and it goes to acer recovery over and over but will not boot it help me
Grey screen
Please, try this test:
When you turn on the computer, press the F8 key multiple times to get to a menu (recovery, safe mode). If you get there, select Safe Mode. Once on Safe mode, restart the computer to see if it ever gets to normal boot.
Mar 19, 2013 | Acer Computers & Internet
Restore laptop
If your PC has a recovery partition:
Turn it off.
Before Windows logo appears (after it turns on) keeps pressing F8.
Then you should see Do a system restore?
Keep pressing F8. Then follow what your computer will give you.
If you have a DVD/CD drive and a recovery (reinstall too) disk:
Insert it in.
Turn off your PC.
Turn it on again.
Then keep pressing F12 or F8 (any works).
After that you should see a boot-menu.
Select the option which says to boot from the CD/DVD drive.
Then follow the instructions.
Jan 24, 2013 | eMachines Acer G620 G720 Lcd Cable Gle...
How do In use the eRecovery on the Acer Aspire 7741Z-4433 with Windows 7?
Hello, to use the built in recovery with your laptop you need to do a few things. First, turn off your computer. When turning it back on immediately start pressing F8 until you get the advanced boot options screen. An option there should be repair my computer. If that does not work, you want to do the same thing but press F4 instead of F8 constantly. If F4 does not work then you want to press F9. Try them in that order and you should be taken care of.
Thanks for using FixYa!
Jul 15, 2011 | Acer Aspire 4520-5582 Notebook
Computer will not boot up, only goes to the windows error recovery page, options to start repair or windows normally, none work it goes back to the same page...
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Jan 07, 2011 | Acer Aspire One PC Notebook
I have the acer netbook model number is kav60 well i go to boot it up a blank screen come up
Sounds like the boot sector is infected or damaged. Try putting in the OS cd for a repair.
Nov 02, 2010 | Acer Aspire One PC Notebook
Acer aspire 6930 black screen only mouse at start up
Please press the CTRL+ALT+DELETE key and select the option task manager, when it open click on file and click on the new task and type over there"explorer.exe " and press the enter key.
if it is notr working then shutdown the computer and when you start it press the f8 key again and again ansd select the option safe mode with networking" after the login with safe mode with networking"restore the computer" on the previous date.
Nov 09, 2009 | Acer Aspire 6930-6771 Laptop
PC freezes on boot-up
Try booting the thing in Safe Mode. Upon startup (after the Acer logo goes) press F8 several times. You will be offered a menu select Safe Mode (at the very top of the list). If the system reaches the desktop, you can repair your Windows. For the three fixes below you will need to go Start Menu>Run...
1) Write: fixmbr, and press ENTER.
2) Write: fixboot, and press ENTER.
3) Write: chkdsk, and press ENTER.
(The later will take several minutes, but you can read what stage it is doing).
Apr 16, 2009 | Computers & Internet
My laptop will not boot up.
try pressing F12 on start up to do a full system recovery.
hope this helps
Apr 06, 2009 | Acer Aspire 5720 Notebook
Can get the aspire to boot to windows
try F8, that's usually safe mode. press it like once a second as it's booting.
what's your specific problem-- cant boot windows?
can you try putting a windows install disk in and choosing "repair" when it boots? (you want to make sure you dont format your drive though, repair wont do that usually if youre careful)
Feb 02, 2009 | Acer Aspire 5100 Notebook
Can't Boot
I'm not sure about ACER but many desktops/laptops have a special menu with Safe Mode, LKGC, etc. Try pressing F8 repeatedly as the computer boots up. It should bring you into a menu. Select Last Known Good Configuration. This may or may not work if your backup is faulty but it is the first thing I would try. If this doesn't work I would try going into Safe Mode with Networking and attempt to backup all your data. Once this is done you can recover the OS using the recovery disk. These are generic instructions so please also refer to this link for ACER specific ideas.
http://www.tomshardware.com/forum/243980-32-acer-laptop-recovery-help
Apr 28, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
