Question about Boston Acoustics VR965 Speaker
Who sells replacement cabinet caps and socks for
Who sells replacement cabinet caps and socks for vr965 speakers?
Woofer rattles at low volume...when i turn it up it sounds pretty good...still has bass and highs
May be a couple of things; The first is a resonance in the cabinet, which may not be noticeable at high volumes. If the speaker cabinet was ever dropped,or got cracked from dropping , dry weather,or whatever, there may be certain frequencies that make the cabinet rattle. Try holding the cabinet when it rattles and look for anything loose,from a side wall to a loose foot, or the speaker itself. Tighten up loose items and seal any gaps or cracks On the cabinet.
The other problem could be a partially blown speaker. Test by lightly pushing in on the outsides of the speaker to see if it moves in and out freely. If there is a scratching sound, or it drags slightly , it might be blown. Also,the dust cap or another part of the speaker may be loose. Check that, and reseal if loose. Replace or have reconed if blown.
Nov 02, 2014 | Mackie MR8 ACTIVE STUDIO MONITOR MR-8
I have a Technics PR-305 Digital Piano That has a Distortion in My Speakers it`s not really bad, Would I have to get new speakers, if so where would I get them at? or could they be repaired?
It sounds like the rubber around the speakers has perished. Open the cabinet to check. If so, measure the size and order replacements easily on internet. It's a simple job for someone with a little knowhow
Jan 24, 2014 | Yamaha PSRE413 Keyboard
I have a problem with the tweeter sound in one of my VR975 Boston speakers. The highs seem to come and go. It is definitely limited to one of the speakers because I can switch cable connections in the...
Register and download the manual for free at retrevo.com'
http://www.retrevo.com/support/Boston-Acoustics-VR965-Speakers-manual/id/522dj380/t/2/
A loose or intermittent cable contact on the OUTSIDE would affect ALL speaker output, not just the high frequencies, and it would probably produce speaker-threatening crackles.
That loose tweeter connection the other guys found isn't fixed. Go back and make them fix it right.
What are your present speaker connection ends if NOT bare wire?
Feb 19, 2011 | Boston Acoustics VR965 Speaker
The subwoofers driver is blown and i cant find replacements anywhere? where could i buy a replacement driver?
You may not be able to get an exact original replacement. Most of these systems were never meant to be repaired, just replaced. You can try searching online; there may be a source already identified. You could also try eBay or some other auction site to see if anybody is selling one of these systems. It may not be worth trying to repair yours, though. Amazon.com is selling the system for under $30. Buying just a replacement speaker may cost that much, plus your time and labor to install it.
If you really want to try repair, a good source of replacement speakers in the US is Parts Express. (I don't know if they ship internationally, I've never had a reason to check.) They may have something available that will fit the cabinet. If they don't, or you're in some other part of the world, check online for speaker vendors in your area.
Good luck with your hunt, and thanks for using Fixya!
Oct 17, 2010 | Cyber Acoustics CA-3000 Computer Speakers
I have dropped one of my mackie srm450 speakers and i need a replacement woofer.. where can i get one?
If the cone is damaged, it is possible to get it 're-coned'. If you can find a shop that does this type of speaker repair.
Otherwise, call around music stores (by that I mean places that sell musical instruments and PA gear) and see if they sell/sevice Mackie. If you are comfortable taking the old woofer out, just order the part and DIY.
It is not critical that the woofer is an exact replacement (doesn't have to be a Mackie speaker), the important things are:
1) it fits and screws back into the speaker cabinet
2) it is electrically similar to the original (same impedance 4 ohm or 8 ohm) and wattage rating
Feb 06, 2010 | Mackie SRM-450 System
Where can I get new connector terminals for my VR952 Boston towers?
Cheapist place for those connectors would be radio shack.
Jan 29, 2010 | Boston Acoustics VR965 Speaker
TOP LOADING WASHING MACHINE HAS A SOCK STUCK IN THE PUMP LINE, HOW DO I REMOVE THE SOCK
flip up the control panel and pop the cabinet clips. Remove the cabinet and the pump is right in front. All you need is pliers and a screwdriver.
Jun 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kef k160 sp3134 hi i was wondering if speaker parts canbe purchased for these. also i wastrying to figure out whether you access the speakers inside the cabinet. thecabinets are sowellmade it is not easy...
I have a good KEF K160 tower (one speaker) for sale. I purchased the pair and one had a blown woofer. After trying to replace/repair, I purchased a pair of KEF C40s and been happy ever since. The good K160 looks and sounds good. Grill and cabinet in good shape, both black finish. Other speaker cabinet is in poor condition. I'll sell the single (or both if you want to pay shipping) for $75. (Plus shipping, around $50 USA ground delivery) These are hard to find.
Jul 17, 2008 | Audio Players & Recorders
Boston Acoustics VR965 Speaker Logo
24 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
