Question about Nintendo Wii Console
I have a wireless router from DMAX that works perfectly on the computer with the wireless program. I keep trying to test the connection on my Nintendo Wii with the wireless program, but still the error code 52030 appears saying that I am unable to connect to the Internet. I hope I clarified correctly my problem this time. I hope you guys know what to do.
  • rgrandberryf May 11, 2010
    bbring it in to best buy they can help you bye
    time to get a new one
    Genius:
  • 1,234 Answers
Error Code: 52030 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Posted on Aug 27, 2010
Stopped working on my computer
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jul 19, 2010 | Linksys Wireless-G WRT54G Router
I have a cisco WRT160 router and have lost wireless to laptop
Change all the wireless settings of the router.
Change the SSID ( network name ). change the SSID something new that you never tried before. change the security to WPA personal.
change the channel to 6.
make sure the wireless MAC filter is disabled.
under advanced wireless settings change the beacon interval to 75.
Now on your computer try to connect to the new network name.
see if that works.
If that doesn't work then try to upgrade the firmware./
Click Here for more information on routers
Jan 04, 2010 | Cisco (WS-X3011) Router
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
Just installed a netgear rangemax wpn824v3. Everything works perfectly for the PC laptop in the house; upstairs, downstairs it doesn't matter. The problem is my powerbook mac won't connect unless I go to...
If you want to upgrade the firmware on the router then please do it on a hardwired windows computer. Firmware wont upload on the router through a MAC computer. I would suggest you to follow the steps below to configure settings on the router:
Scan for the wireless network on the wireless enabled computers and connect to the network.
Hope, this helps.
Aug 08, 2009 | NetGear RangeMax WPN824 Router
Not able to install the software, tells me mdm.exe has stopped working and won't go any farther
Manual Setup: This option is best if you cannot use the wizard on the CD, are replacing an
existing router, or are technically knowledgeable. Follow the instructions in this manual to set
up your router.
Connecting Your Router
1. Connect the router, the computer, and the modem.
a. Turn off your computer.
b. Turn off and unplug the cable or ADSL broadband modem.
c. Locate the Ethernet cable (1) that connects your computer to the modem.
d. Disconnect the cable at the modem end only (2).
e. Securely insert the free end of the cable (1) into a LAN port on the router, such as LAN
port 4 (3).
f. Securely insert the yellow cable (5) that came with your router into the yellow Internet
port of the router (4) and the other end into the modem (2).
Setting Up Your Router for Internet Access
To access the router using its login name and password, follow these instructions.
1. Connect to the router by typing http://www.routerlogin.net in the address field of your
browser, then click Enter.
For security reasons, the router has its own user name and password. When prompted, enter
admin for the router user name and password for the router password, both in lower case
letters.
Enter the user name and password. The router will display its home page.
When the router is connected to the Internet, click the Knowledge Base or the Documentation link
under the Web Support menu to view support information or the documentation for the router.
If you do not click Logout, the router will wait 5 minutes after there is no activity before it
automatically logs you out.
Set Up and Test Basic Wireless Connectivity
Follow the instructions below to set up and test basic wireless connectivity. Once you have
established basic wireless connectivity, you can enable security settings appropriate to your needs.
1. Log in to the router at its default LAN address of http://www.routerlogin.net with its default
user name of admin and default password of password, or using whatever LAN address and
password you have set up.
2. Click the Wireless Settings link in the main menu of the router.
3. Note that the default SSID is NETGEAR.
4. Set the Region. Select the region in which the wireless interface will operate.
5. Click Apply to save your changes.
6. Configure and test your computers for wireless connectivity.
Program the wireless adapter of your computers to have the same wireless network name
(SSID) as the router. Check that they have a wireless link and are able to obtain an IP address
by DHCP from the router.
Note:
Apr 19, 2009 | Computers & Internet
My D-link Wireless router not working.
G´day again m8 :-),
Your D-Link AirPlus G DI-524 Wireless Router needs a hard reset.
Log in to your router, go to -> administration -> factory default -> Restore Factory Defaults: =  “No”
Then save settings.
You have now reset the router.
First thing you do is set your wireless setup in your computer to the same, i.e. no security.
Test if there is connection, if, the start with the setup from the top, beginning with admin password.
/Teis
NOTE, be paitient after reset, your router need to contact Telstra to optain your IP address.
- - - - > vote
Dec 19, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
Cannot connect to router wirelessly.
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
May 09, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Laptop keeps disconnecting then connecting every so often.
Has the computer ever stayed on long enough to connect to the internet?
Is there a wired computer working when attached to the router?
If not, if possible please try to connect the laptop wired to the router as a test and tell me if it works.
I am trying to determine if your router works with the internet before considering the wireless connection simplying the initial problem. Once the router works wired is time to try the wireless. Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network. So this can be a three step process.
Jan 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get online or pick up a wireless network?
A couple of issues and questions
First generally a wireless router in installed onto a network either to the ISP's modem or to another router that is connected to an ISP's modem it is not connected on the wan side to a computer (unless that computer is acting as a firewall or proxy server to the internet). Computers are generally connected with a wire to the (optional) switch portion of a wireless router or wireless connection.
Have you tried testing with a computer wired to the router to assure internet access is possible without worrying about wireless issues?
If you are considering encrypting the wireless router did you test it unencrypted first to assure the unencrypted radio transmissions work?
Is the wireless communication encrypted for other computers you own and possibly not for the HP you are now trying to connect?
Are you sure the distance between the wireless router and the garage is not an issue. Perhaps you could test and configure the connection in the room with the router and when it is working move it to the garage.
According to the product specs for the HP Pavilion it has built in wireless B & G you did not include the router manufacturer and model does it operate on the either wireless B or G?
Dec 08, 2007 | Computers & Internet
Nintendo Wii Console Logo
1,115 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
