Question about Bravetti EP4305FS Deep Fryer
I need reset switch part # WQS-260 where do I purchase one
When I turn my pump on it kicks the breaker. What is wrong with the pump?
sounds like pump motor is rusted you can try to turn by hand when off then try again if not need new motor
Jul 02, 2014 | Pool & Spa
I dropped my Garming Nuvi 260 this past weekend and when I turn it on it goes to a screen saying Updating GPS Firmware 1% then jumps to Updating GPS Firmware Complete. It keeps popping up with these...
Inspect the bottom of your Nuvi 260. According to the owner's manual, some models have a small "Reset" button on the bottom. If yours does, you'll use this to reset the Nuvi 260.Press and hold the "Reset" button for several seconds, until the Nuvi powers off and powers back on. Next try
to slide the power switch on top all the way to the left to reset your Nuvi if it does not have a "Reset" button. Performing this action resets the system.
Next try a hard reset.
Slide the power switch to "Off."
Press your finger against the screen in the lower-right corner. Hold your finger in this position.
Slide the power switch to "On" to turn the Nuvi on. Continue holding your finger on the screen until the pop-up window appears. When it does, press "Yes" to reset your Nuvi to its factory settings.
Hope this works but dropping may have caused internal damage. If this does not work you may have to send it back to Garmin for service. I will attach a link for Garmin. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/
May 30, 2011 | Garmin nuvi 260W GPS Receiver
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
The thermostat is stuck at 260. How do I reset
you need to replace the thermostat and gasket,for some reason your engine is over heating,check to make sure fluid level is full ,and cooling fan is turning on by 212 degrees,
Dec 10, 2009 | 1997 Chevrolet Suburban
Channels keep chaning
just ensure someone isn;t playing tricks on you here. had a case recently where a neighjbors kid programmed a remote and kept changing channels while he wqs outside window.
Also check your own remote has not got a faulty or sticky button.
Sometimes a computer close by can do this or even an A/C switching in and out. Turn some other things off to eliminate this posssibilty and prepare a gallows for the kid next door if you see him in the street with a remote
Aug 14, 2009 | Televison & Video
I have a Nuvi 260. Where is the reset button? The manual that came with the unit is for a 200. Is the button under the sticker somewhere?
It hard to see, not hard to find....look CAREFULLY
Might need glasses to see it depending on your age!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Jun 06, 2009 | Garmin nuvi 260W GPS Receiver
Toshiba with Colour fail , red colour
the filter lense of color red had discolored
Feb 04, 2009 | Toshiba TLP 260 Multimedia Projector
Humdifier wont work
I'm having the same issue
Jan 18, 2009 | Honeywell HWM-260 Humidifier
Pioneer DV-260 DVD player cannot play HD DVD
thats like trying to play a dvd ina cd player. cant be done.
Feb 16, 2008 | Pioneer DV-260 DVD Player
Bravetti EP4305FS Deep Fryer Logo
Top Bravetti Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Mike
Henry  Thomas
Henry Thomas
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
